Old 01-16-2006, 04:31 PM   #1 (permalink)
Slow/Jumping Speedometer
A few weeks ago my speedometer started jumping. Nothing serious, just about +-2 mph. So I pulled the cable out and greased it up real good. Made it worse to the point that it shows 25mph when I'm traveling 60-65 mph. So I'm thinking maybe I put too much grease on it or the grease is too thick. So I pulled it out and dowsed it with WD-40. That helped a little bit but not much. So I pulled it out again and tried white lithium grease. Still no good. Its bouncing about +-5mph and reading around 20-25mph too slow and I'm getting tired of pulling the dash apart. I've also took the speedogear out of the tail of the transfer case and inspected it. It looks to be fine. Whats the problem?
1989 F250 XLT Lariat, 7.3L n/a IDI, 4x4, C6
mhalter is offline
Old 01-16-2006, 05:09 PM   #2 (permalink)
My Photos: (17)
Re: Slow/Jumping Speedometer
Well, if it's not the cable, it has to be either the driven gear(easy to replace, the drive gear(hard to replace) or the speedo head(hard and expensive to replace) [img]/ubbthreads/images/graemlins/shrug.gif[/img]. "Copy" and "Paste" the address below into your address bar. They have lotsa info and parts. OkieGringo
http://www.tciauto.com/tech_info/speedo_gears.htm#700R4
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 01-16-2006, 09:27 PM   #3 (permalink)
Get yourself an inspection mirror and a bright flaslight and crawl under the beast. remove the cable and gear from the transfer case and have yourself a peak down the hole that the gear came out of...You should see a yellow gear on a shaft. The yellow gear should be totally visible, and not offset in the hole. Stick your finger in the hole and feel the yellow gear. Note things like how the teeth feel...are they arounded off etc? If that all looks good take the gear off of your cable inspect it...look down inside of it where the cable sticks into the gear...is the square hole rounded out, making it not grab all the time? If that all looks good, put a drill on the cable and run it in reverse...make sure you can see your speedo or have someone with you who can look at if...if the speedo still registers wrong your are down to 2 things, crappy cable, or bad speedo head. Good luck.
Shawn
Custom farming in NWIA.
tractors:
706,806,1206,1256,5288,7140mfd.
vehicles:
-1985 Ford F250 reg. cab,blue w/ extra clearance lights,4x4,T19 4 gear,3.55's,Banks sidewinder w/ K&N, 3.5" straight pipe, 2 gauge pillar, and 3 below dash. Pioneer cd player & a pair of 12" RocFos subs shoved behind seat. Old school tuned Midland 23 channel CB w/ PA and 13 foot whip antenna, Solara DSC marine-band and 4 foot midland antenna hooked too a Delta diamond plate tool box, Aluminum rims,hide-a-ball, RoadMaster drop rear bumper,air gate, and stainless stick on's on the bottom body line.
-93 Ford F250 7.3L IDI Turbo Diesel, ATS upgrades, 4" exhaust and 5" stainless tip, 5 speed, 4wd, 3.55's, maroon on silver, American Racing rims, custom built air gate, DMI rear bumper, extra clearance lights.
-61 Ford Falcon Futura, 289HIPO, T10 4 speed, 9" rear w/ cleveland locker and 3.55's, linelok, Granada front discs.
Mosin Nagant's, K98's, K-31's, Enfields, AK's, and SKS's.
twelve0six is offline
