I'm lucky! In Newport Washington we don't have smoke tests. Mine would probably pass one if I turned the IP pump down, but she smokes a bit right now. I turned the screw over a third of a turn and she has a lot more giddyup and go now that she smokes. The more smoke, the harder she pulls for some reason? [img]/ubbthreads/images/graemlins/shrug.gif[/img] Fine with me though [img]/ubbthreads/images/graemlins/grin.gif[/img].
American by birth, Southern by the grace of God!
1991 F250 7.3l 200XXX extended cab long bed. 3.55's REDNECKED OUT!! 295/75/16 Bfg All Terrains 16 in billet rims. New front brake pads and rotors, rear shoes, glow plug controller, glow plugs, return line kit duralast batteries, mitubishi off set gear redution starter, altenator, valve cover seals, holley red pump,new injector pump, soon to be new injectors, new vacum pump. Removed soup bowl and drilled holes in air intake.
Here in Ohio trucks need to be tested up to 10,000 GVWR. 10,001 GVWR, no test. However, anything over 10K must have commercial plates, regardless of use.
Funny, my 3/4T van is registered at 10,001. Strange how that happened??
