Smoking 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 06-09-2010, 12:12 PM Thread Starter
Smoking 7.3
My 7.3 IDI is smoking during idle and quick deceleration (just a puff). Easy take off and shifting (manual) it's clear. Really wind it out and you'll get a puff at shift. Long downhill's where your not into the throttle, but not totally off it would make a Sherman Tank proud. The smoke is constant and blue in color. I have no loss of power issues and the smoke appears to be little or none under a load or normal driving. Truck has 200,000 on it with only glow plugs replaced. I've been told heads, injectors, and pump. Anybody have a tight answer?
RM Costa is offline
post #2 of 8 (permalink) Old 06-09-2010, 12:18 PM
cdnsarguy's Avatar
My Photos: (109)
Smell the smoke is it fuel or oil.......
200K would be time for injectors, possibly IP if the MPG is down...
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 8 (permalink) Old 06-09-2010, 03:34 PM Thread Starter
I guess it would lean towards a fuel smell, even sorta anti freeze. Not or haven't lost water. Fired up this a.m. (Oregon 68 degrees) on GP only. Barely visible trace of smoke, and all the way into town without a puff. If left to idle for long, it will start smoking, and not continuous but with occasional puffs and stutters as if it's missing. Sometimes when running along about 60 it feels like it's surging or not getting an even fuel feed.
RM Costa is offline
post #4 of 8 (permalink) Old 06-12-2010, 10:21 PM
sorry to see you have not had a reply to you last post I have same issue and have a question posted on here on the hard start when hot post anyway if i get an answer from someone or figure this issue out I will let you know as it will help you as we both have the same problem exactly.
scorpiontimothy is offline
post #5 of 8 (permalink) Old 06-13-2010, 09:23 AM
fergy94f250's Avatar
my truck smokes ton of black smoke under load or when you chop on it i know i need a new clutch and throw out bearing but tring to milk it for a bit but my truck first thing in the morning throw white smoke smells like diesel it misses then after high idle is off it runs like a top any thoughs i'm thinking glow plugs and pump but no idea
94 F250 5 speed 7.3 IDI turbo 4x4 ext cab long box
fergy94f250 is offline
post #6 of 8 (permalink) Old 06-13-2010, 09:32 AM
chuckster57's Avatar
Blowing white smoke at start-up is usually caused by air in the lines. Mine did that and I found the seals on the supply line from the filter to the IP were bad and the line was draining off onto the valley when the truck sat.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #7 of 8 (permalink) Old 06-13-2010, 09:41 AM
drinkypoo's Avatar
My Photos: (25)
pssst high idle is "cold advance", it's not an idle change per se, but a timing change. the injection timing is advanced. but I don't know enough about diesels to know what it means if they burn excess fuel during the cold advance.
if chuckster says you probably have air intrusion then you probably do. I've been thinking of replacing all my fuel lines with clear (Eurbraid?) so that I can see if I have problems like this. I don't see any reason one couldn't do it to the injector return lines, too. The only big problem is temp resistance in that area.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #8 of 8 (permalink) Old 06-16-2010, 10:09 AM
just fixed mine had allready replaced my o rings and injector lines still have smoke so replaced 5/16 line from IP to fuel steel line cleared it up also check your air filter I changed mine to a better one opened up the breathing no smoke at all one other thing I did was turn the IP up about 1/8 inch losen 3 bolts and turn toward passanger side bolts are 9/16 and hard to get to but do able all this resulted in no more smoke a more smoth running and more horse power than before good luck
