Old 03-21-2005, 08:23 PM   #1 (permalink)
Solid front axle conversion questions
Can someone point me in the right direction for some info on converting at TTB F250 to a solid front axle?
My buddy has a '96 and the front diff is shot (it puked its innards out of the front cover), due to the previous owner's maintenance skills... We were thinking that if he needs a new diff, and balljoints, wheelbearings, rotors, etc... It might be easier to just swap in a completed D60.
Anyway, send responses to my email address, reklund5@comcast.net
as I can't access the forum from work.
Ryan
1992 F250 4x4 5spd 81000 miles, slowly upgrading...
1984 Toyota truck- Rockcrawler- EFI Conversion, dual transfer cases, gears, lockers, 37's, etc...
1987 Toyota Supra Turbo- all the goodies 400RWHP
reklund is offline
Old 03-21-2005, 08:36 PM   #2 (permalink)
Re: Solid front axle conversion questions
a D60 from 87-97 F-350s should work. You'll want to find a single rear wheel (SRW) axle, otherwise, you'll have to remove the dually "adapters". 98(?) and up used 8 on 170mm instead of the standard 8 on 6.5".
New rig: 1995 Dodge 2500 LB, Reg. Cab, 4x4, Cummins, 3k GSK, Hillbilly plate ground, 4" exhaust, 285/75/16s
Old rig:
1989 F-250 7.3 IDI, 4x4, 4" Rough Country Lift, Hypermax Turbo, 128K, 5 Speed, 4.10 gears, Custom air intake, "MIG-Made" Propane Kit, 3.5" Dual Chrome Stacks w/ straight exhaust, 285/75/16 tires on Classic 589s, Pioneer MP3 Player with 10" sub, Galaxy DX959 CB. Savin' some bread for some new 315/75 shoes.
My drinking team has a rockcrawling problem.
Hold it 'til the valves float!
nosliw is offline
Old 03-21-2005, 09:06 PM   #3 (permalink)
Is the axle just a bolt-in affair? Will we have to change any of the steering parts, driveshaft, U-Bolts, etc?
Ryan
reklund is offline
Old 03-21-2005, 09:58 PM   #4 (permalink)
My Photos: (13)
Yup, bolt in deal. Pretty easy, just bolt in the spring, plumb in the brakes and you are off to the races, there is a little more to it, but not much. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
Old 03-21-2005, 10:44 PM   #5 (permalink)
Will we need to change the springs?
Ryan
reklund is offline
Old 03-21-2005, 11:08 PM   #6 (permalink)
You will want to use the F-350 springs, just mainly for height. The 250 springs are arched differently than the 350. Mine was a very simple install and am muck happier with the straight axle.
2006 F-350 XLT,FX4 4X4,CC,SRW,LWB,6.0, auto
IHpower is offline
Old 03-21-2005, 11:57 PM   #7 (permalink)
I may do this in the future too. I was kinda under the impression it involved some custom fabrication. I am getting tired of the TTB. Today I got new tires for my truck and was going to have it aligned, but the tech pointed out that the draglink was bent, I just replaced it in January. So I had to get another and I will be replacing it again tomorrow and taking the truck back to the shop for alignment. Making me wonder if the D60 isn't a better deal..... Scotty mentioned teh brakes...are they the same or different?
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 03-22-2005, 12:21 AM   #8 (permalink)
No fabrication at all. I just took the trac bar bracket off the F-350 and mounted it on my F-250. The 250 had a bracket similar to the 350's but not the same, but they both use the same bolt holes on the crossmember. Trust me it is a simple conversion. As far as the brakes go, I had the complete brake setup come with the axle so I just hooked my brake lines up to the new axle's calipers.
IHpower is offline
Old 03-22-2005, 12:36 AM   #9 (permalink)
Don't forget the 4" lift blocks in the rear. The front driveshaft may need to be shortened. The springs from the 250 will give more lift than those from a 350 provided they are not worn. It was by far the best mod to my truck.
1989 F250 XLT Lariat. 1994 7.3 IDI transplant. 4X4 with a Dana 60 up front. Rebuilt C6, Husky diamond plate tool box, DeeZee running boards, bedliner and TracRac. Boss Superduty 8 1/2' plow.
CJ7Laredo is offline
