Just bought some 5" rain caps for a set of straight cut stacks. I might put these on my 7.3IDI or I might put them on another work truck. I wanted to see if any of you guys had a sound clips of straight piped 7.3IDI's ...I searched all over the net for one and never did find any?
Im no Einstein...but I might be a Rocket Scientist !
Sounds like under excelleration that it could be really loud like a open header gas motor right? Im guessing because of no turbo its louder?
Correct
i had an IDI turbo, and ran it straight piped, the turbo muffled alot of the sound, IE there is less fuel goin out the tailpipe and it is bein used by the turbo, so the sound it less.
A friend of mine had a 92 non turboed engine, and DANG! sounded just like that clip..
Tx
96 2500, CTD 12v, 3.54 gears, NV4500, 4x4, Banks Powerpack, skyjacker 2 1/2 inch lift, BFG all terrain 285's all around on progressive rims Gooseneck hitch, reciever hitch, brushguard, side steps, Pyro gauge, boost gauges from banks, headache rack, toolbox, some other extras
Those are illegal.Well atleast in texas as far as I know.Got some information from the dps that only a diesel with a turbo can be straight piped and that a naturally aspirated non-turbo diesel is illegal to run on the highway with a straight pipe.
Also another thing to mention about vehicles with turbos.Its also okay to have a gasoline vehicle with a turbocharger to run it straight piped.I was suprised with a gasser being able to do that oh well.
So any turbo can run with a straight pipe.
I fixed my n/a 93 ford with a muffler,but under one condition,the muffler's completely gutted.Had to do some fab'n but got it to work so i still screwed those tree-huggers over. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
I ran a single staight pipe for over a year no problems sounded great
Then I decided to put on dual 2 1/4" Staight pipes with 18' 3 1/2" Slash Cut tips all I can say is [img]/ubbthreads/images/graemlins/shocked.gif[/img]wow one pass by the Ford Stealership(setting off atleast 2 maybe 3)car alarms off I had to turn around and put some mufflers on
Now with this cummins my truck sound really quiet even with a straight pipe
2000 Crew Short F250 4x4 Lariat
White over Ebony
Limo Tint all the way around
F350 Blocks- 1 1/2" Shackle kit up Front
Eagle Alloys
265/75/16 Toyo Open Country M/T's
5" straight pipe
~sold~
1992 Ford F250- excab- 4x4- Canary Yellow- 12 valve Cummins Swap- NV4500 5spd-
"Ford Makes It-Cummins Shakes It"
Rip Rook's 4inch straight pipe exhaust
~custom~ fuel plate
Pump Timing Set to 17*
Isspro Pryo and Boost Gauges on the Pillar
rolling on 285's Toyo M55's
I have mine true dualled with mufflers but no tips. Everyone tells me it sounds like a big block when I stand on it. Not quite as loud as that sound clip but close.
1993 F250 7.3L IDI non turbo 4x4 5-speed. Reg. cab, long bed. true dual exhaust 33x12.50 BFG A/T's 350,000 miles
