Old 12-19-2005, 09:07 PM   #1 (permalink)
My Photos: (10)
spindle & rotor HELP
me being the king of procrastination, let my bearing get melted to the drivers side spindle. i heard it squeaking a bit but i thought that "oo its not too bad, ill get it this weekend" , well when i was driving home from work, i turned a corner and it sounded like the wheel was about to fall off. so i crawled home and took the wheel off, and the bearing is pretty much gone and i cant get the rotor off.
does anybody know how much it costs to have someone fix/replace the rotor and spildle, one guy quoted about 485$ with alignment, is that a reasonable price?
thanks kevin
(mine) 94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a used p-stroke exhaust on the end of it 24xxxx miles, amsoil bypass, coolant filter
(dads) 02 350 7.3 powerstroke crew cab 4x4 ESOF
mods: itp in tank/prepump, 4 inch exhaust, ats housing, western diesel gauges, 6.0 transmission cooler, 6.0 Banks "technicooler" intercooler 150 bucks , coolant filter, "OEIS", b&w 5th wheel companion
18xxxx miles
my gallery
WHY THE HELL SHOULD I HAVE TO PUSH 1 FOR ENGLISH?
H O N D A - How Odd No Damn Acceleration
radeon1314 is offline
Old 12-19-2005, 10:45 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: spindle & rotor HELP
4x2 correct.......
Did you remove the outer nut and bearing, if so just push the rotor and hub in as far as possible then jerk it back out with all your might. I bet it's the outer bearing right..........if so you may need a torch. Can't see that amount of money required to burn off two bearings, replace seal plus 2 bearings and lubricate. No alignment required??? I would seek a second opinion......should be about $150-200 MAX. including tow to shop if you have AAA.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 12-19-2005, 11:14 PM   #3 (permalink)
My Photos: (10)
the guy i brought it to, he finally got the rotor off and he said and i saw that the spindle was turning a purple color, and he said that it may be warped. so he will have to redo the ball joints and get a new spindle so does 485 sound about right for all that
thanks and merry christmas,
kevin
18xxxx miles
my gallery
Old 12-19-2005, 11:15 PM   #4 (permalink)
My Photos: (10)
yes 4x2
18xxxx miles
my gallery
Old 12-20-2005, 07:20 AM   #5 (permalink)
kevin
If he is telling you the ball joints need to be done because the spindle needs to be replaced he is screwing you,now thats not to say the ball joints are not bad,just that the 2 are unrelated when it comes to replacing one or the other.
1992 f-350.4x4 srw.rebuilt e4od.rebuilt injection pump. no soup bowl,no muffler,straight pipe.. 8 foot power angle Artic blade/7 1/2 ft p/a Fisher blade. 280,000kms and counting.Paint to come.
pnose is offline
Old 12-20-2005, 07:57 AM   #6 (permalink)
If the spindle doesn't have any cuts or gouges in it just stick it back together and run it. You can find good used spindles if that's what you need. If you heat a spindle to cut off a bearing it will turn bluish purple. I would doubt you got it hot enought driving it to bend it. I thinl the mechanic smells some easy money.
Greg
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
Greg77 is offline
Old 12-20-2005, 08:14 AM   #7 (permalink)
cdnsarguy's Avatar
My Photos: (66)
I agree just have the bearings etc replacd and put it back together. Tell the mechanic if any problems arise you can bring it back later when Christmas is over........$$$$ are short right now.
Old 12-20-2005, 11:11 AM   #8 (permalink)
i did this same thing to an f150.
by the time we got the spindle cleaned up it looked pretty rough.
i went to a local truck junkyard, and they sold me the whole wheel assembly, ball joints and out for $35.
drew
'89 F250 7.3 IDI, c6, 3.55rear, 2wd, 152k miles
DeepRoots is offline
