Stack question - Diesel Forum - TheDieselStop.com
Old 10-24-2005, 11:39 PM   #1 (permalink)
Stack question
Ok Boys,
The fact is that now that I have looked at all the options and somewhat facts like, I live in the snow for almost 5 months out of the year, I cross alot of creeks, I want more power and I want my IDI to be my camp/survivial rig, this being said, I think I might want to finaly go with stacks. The base question is , how hard is it to do?Next question, how big? We have a guy here in town that has a set of 3.5 he will sell me for about 100 bucks. What do y'all think?
Mike Rodriguez
El Rancho Lobo, Lookout, State of Jefferson
1976 F-350 4x4, 390
1992 F-350 4x4 Crew Cab, 7.3, Auto
76and92ford is offline
Old 10-25-2005, 12:28 AM   #2 (permalink)
Re: Stack question
When I do stacks I'll probably go 4 or 5" and I don't think $100 is a steal or anything. You are na, correct? I'd get custom exaust down starting either at or very close to the manifolds and run true duals and probably with mufflers.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 10-25-2005, 12:43 AM   #3 (permalink)
Re: Stack question
Call me weird but I've always wanted stacks with the old flappers i like the way they jingle at idle.
[img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/vulnerable.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img]
1989 F250 7.3 N/A 2wd bone stock finally fires in the cold!!!!!!!!!!!!!!!!!!!!
dont miss out ***************
Proud BOOB man http://p087.ezboard.com/bmidatlanticforddieselclub
dbarilow is offline
Old 10-25-2005, 01:40 AM   #4 (permalink)
xtremefreerider's Avatar
Re: Stack question
I ran 5" on mine and they did have the old flappers in the winter. They drove me nuts. I currently have two sets of stacks, one brand new pair of turnouts and a 1.5 year old pair of straight w/ flappers. I could make you a deal on one set if you like. It took me about a day to install but I really didn't plan it out nor did I take it easy the night before. I would suggest using a bit of flex pipe under the cab to allow for the flex in the truck. I would also suggest some kind of mount to the bed rail to prevent massive vibration. I used a band clamp bolted to a piece of steel that bolted to the rail. Because the stacks are bolted to the bed and the other end of the exhaust is bolted to the motor you must allow for some flex.....expecially if the thing is used off road at all.
-Brian
1990 F-350 REG CAB LONG BED, 7.3 IDI, '95 ZF-5, LUK CLUTCH W/ SINGLE MASS FLYWHEEL, 87 BW 1356 T-case, FOUR GAUGE PILLAR MOUNT W/ AUTOMETER BOOST, PYRO, OIL PRESSURE AND WATER TEMP, BANKS SIDEWINDER WASTEGATED TURBO, EAGLE 16.5" WHEELS, 4 INCH SUPERLIFT, 35/12.5/16.5 BFG Muds, Eaton Rear End (7/05), Blown Motor (9/05), New motor, trans and t-case (9/06), Custom 5" straight pipe (8/07) - Pics coming soon....odometer rolled for the second time...although I don't have the correct spedo gear and the spedo/odo didn't work for 15-20k miles
MY PHOTOS
The Goat - 2008 Dodge 2500 CC LB 4x4, 6.7L Cummins w/ 6sp manual. So far bone stock except a leveling kit
xtremefreerider is offline
Old 10-25-2005, 08:39 AM   #5 (permalink)
My Photos: (23)
Re: Stack question
A 4" chrome stack from a truck shop will run you about $80 each. Plumbing them and mounting them is not hard, just requires a little inginuity.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, Moose Mister Injectors, Hypermax Turbo, Intercooler, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 10-26-2005, 01:52 PM   #6 (permalink)
My Photos: (27)
Re: Stack question
What are you lookin to get for the stacks with the rain caps? I'm in SoCal and would be willin to pick em up if the price is right! Shoot me an email at superf350@yahoo.com.
IRAQI WAR VET AND PROUD OF IT!
2008 F250 FX4 6.4
SUPERF350 2006 F350
POWDER COATED CAC TUBES
PROJECT TRUCK 85 F250 4X4 6.9 6.0 IN IRAQ
superf350 is offline
Old 10-26-2005, 02:39 PM   #7 (permalink)
Re: Stack question
I like 5" myself 4 is okay any smaller and I don't think they fit the truck very well 3.5" is okay for a tail pipe but you have to realize you only see about 12" of it now when you have 3' sticking up it makes the pipe seem skinnier. I have pics of my setup but mines turbo'd
Aric
96 F-350 4x4 regularcab dually 5spd 4.10LS [color:"red"]Home made Bumper[/color]DIY open air intake hypermax dp 4" exhaust DIY exhaust brake [color:"red"]Dump bed[/color]
93 F-250 factory turbo 4x4 extended cab [color:"blue"]MyPics[/color] 4.10 5spd K&N filter ATS outler and down pipe 3in exhaust to twin 5" stacks tweaked wastegate turned up pump LUK clutch boost and pyro and much more to come[color:"blue"]Mickey Thompsons classic II 265 75 16 Courser C/T[/color]
Ford makes it IH shakes it
Don't worry about the mule just load the wagon
93turbo'd_animal is offline
