Old 01-25-2007, 06:21 PM   #1 (permalink)
Starter
my 91 ford 7.3 IDI will still turn over if i get under the truck and cross the silonoid over on the starter. So the starter is still good but which silonoid is bad ??
1991 ford f-350 XLT 4x4 Reg cab Flat Bed,7.3L IDI all stock, 5spd and 4.10 (very loud)
1992 ford F-150 XLT 4x4 auto with a 5.0,
Just a Broke High Schooler
fordtrucks is offline
Old 01-25-2007, 07:37 PM   #2 (permalink)
Re: Starter
Are you jumping across the 2 big terminals or applying power to the small terminal?
Your fender mounted solenoid simply sends power to the small terminal on the starter mounted solenoid, which closes that solenoid and sends power to the starter.
Start your diagnostics topside. Run power to the small terminal on the fender mounted solenoid. If the motor turns over, the solenoids are OK, and you have a wiring problem.
If it doesn't turn over, jump across the 2 big terminals on the fender mounted starter. If the motor turns over, then the fender mounted solenoid is bad.
If it still doesn't turn over, then jump power to the small terminal on the starter mounted solenoid. If it turns over, then there is a wiring problem between the 2 solenoids. If it does not turn over, then the starter mounted solenoid is bad.
Just follow the power progressively from the ignition switch down to the starter until something doesn't do what it is supposed to do.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 01-25-2007, 08:34 PM   #3 (permalink)
Re: Starter
i took it into the parts store to have them test it and the solenoid on the starter is bad
