Old 01-27-2007, 06:02 PM   #1 (permalink)
Starting issue
Since I bought my truck 2 months ago it has been hard to start, Most of the time it will start up right away and die after 1-2 seconds shooting out white smoke after it has sat awhile (1 day or longer) then I have to cycle the glow plugs about 10-15 times and it will finally fire and stay started and run really well. After its been driven awhile it will start up fine as long as I dont let it sit longer than an hour. Changing the starter and fuel filter has helped some. Two shops have told me 2 different solutions: 1st shop said I need a new IP, new injectors and injector lines (I hope not) and the second shop told me I need a new GP controller and relay. Any advice that can help me pinpoint the solution would be helpful since I dont want to start throwing parts at it.
1997 Ford F150 Supercab Flareside
5.4 Trition w/150k
Auto trans
Completely stock except for new shocks and injectors
celticthor is offline
Old 01-27-2007, 06:08 PM   #2 (permalink)
Re: Starting issue
Problem is an air leak in the fuel system, probably your injector O-rings, caps, and fuel lines between. they can be purchased in a kit called injector replacment kit for around $30-35.
91 F-350, SRW, CC, 7.3L IDI, 4X4, ZF5, K&N air filter
bcgeorge is offline
Old 01-27-2007, 06:08 PM   #3 (permalink)
Re: Starting issue
just a thought but maybe your fuel pump. i had the same problem the truck would start then die and then you would have to crank it for ever before it would start. the pump is cheap and easy to put on
1996 Crew Cab 7.3 DRW 5sp Banks Power kit, Luk Clutch, Air ride, Down pipe,Exhaust brake, 219,000m
1996 Super cab 7.3 Auto DRW, stock, 764,000m (RIP)
1986 Reg Cab 6.9 4x4 Auto 61,000m
1997 Crew Cab Centurion Conversion DRW 162,000m auto stock (wifes truck)
2005 Crew Cab F350 DRW 4X4 sport auto 6.0 leather 145,000
NCCER certified Heavy equipment operator
dirttracker05 is offline
Old 01-27-2007, 06:12 PM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Starting issue
What you need to do is search for posts re air in the fuel system. Look for info on http://www.intellidog.com/dieselmann/home.html re the air leak points a on the fuel filter...... I think he also has the instructions for the clear hose in the return 2 lines.
Your exhibiting the classic symptoms of fuel drainoff...... air enters the system via a bad seal or sensor or return line oring and allows the IP to retain just enough for a start. Then you have to re prime the upper part of the system.... filter/IP etc.
Possibly linked with a GP problem......how long does the WTS light stay on......
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 01-27-2007, 06:15 PM   #5 (permalink)
Re: Starting issue
There are times where I can get it to stay running on the first try(about 1 time every 20 starts) and I am leaning toward the GP controller and relay since it wont start at all unless I keep cycling the glow plugs about 10 times. All the glow plugs are good (motorcraft) but I was told (havent confirmed) by a shop that my GP controller was "melted"
5.4 Trition w/150k
Auto trans
Old 01-27-2007, 06:20 PM   #6 (permalink)
Re: Starting issue
Do you get a cycle from the GP controller? How long? Can you hear it clicking after the light goes off? Or see the gage move? that could indicate that the system is working.
BUT, I agree with these guys here. Classic air leak description.
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 01-27-2007, 06:22 PM   #7 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Starting issue
Found your way over here did you.......did I send you the GP controller test before on FTE..............plc7.3
If I did not then I will send it now to your email addy......
Pete
Old 01-27-2007, 06:53 PM   #8 (permalink)
Re: Starting issue
When cold the WTS light stays on for anywhere between 3-10 seconds, it varies alot and I can hear it cycling after the light goes out. If it is a air leak its probably coming from the fuel filter assy, since its leaking from the fuel filter cap and the water seperator at the bottom.
5.4 Trition w/150k
Auto trans
Old 01-27-2007, 07:18 PM   #9 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Starting issue
Check out http://www.intellidog.com/dieselmann/home.html scroll down to IDI info and look for the filter leak points tells you the name of the items on the housing.
Old 01-27-2007, 08:39 PM   #10 (permalink)
Re: Starting issue
Sounds to me like the GP controller is working as designed.
When did you last replace the return lines etc? Done any work around the GP or injecotrs that may have knocked them loose? 35 bucks ant a couple of hours to install a kit would be good maintenance even if it does not fix the issue.
DSBlack is offline
Old 01-27-2007, 11:44 PM   #11 (permalink)
My Photos: (17)
Re: Starting issue
Check the ground wire from the GP Controller to the drivers side valve cover bolt. It must be clean and tight. Lotsa Controller problems have been traced back to this. [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 01-28-2007, 01:05 AM   #12 (permalink)
Re: Starting issue
I will be checking the ground wire tomorrow, as far as the return lines being replaced I have no clue since I have only had the truck 2 months
5.4 Trition w/150k
Auto trans
Old 01-28-2007, 01:58 AM   #13 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Starting issue
What color are the.......grey painted
That ground wire if you can stretch it to the intake manifold bolt that would be better. The 93 engines had a special stud/bolt, you've seen them looks like a stud with a nut in the middle and a washer and nut holds the wire.
