First post. Been reading tons of info online about the problem I'm having, still no dice. :crying:
You guys seemed the most knowledgeable, so here goes.
Purchased truck about 5 months ago, from the second owner of the truck. Purchased with 315,000 miles
give or take a thousand.
Always had long start issues, always hard starts when warm. Recently started having power surging while driving at highway speeds.
Started getting Fuel filter lights, installed a new fuel filter. Still getting light. Starts to stall after hours of working, I do not turn the truck off once its turn on until the end of the day. Stalls start to get worst. Stalls last time and won't turn over even with either. ( Glow plugs disengaged)
Assumed ip stopped working, Install used ip from running truck. Purchased online. Only removed ip, not whole cover during install and removal.
Can't get the truck to restart.
Checked for air intrusion, cracked lines to bleed air out. Used either, no dice.
Put rag soaked in gas on intake, she comes ALIVE! White and Black smoke, then white smoke.
Runs ruff then turns off every time over and over.
Will not stay running, HELP!
Need this truck to feed my family.
