New IP Injectors & Lift pump all in the last six mo Lift pump yesterday she'll start then after 1-5 min dies checked fuel pump pressure at idle 6 psi any ideas?
97 dodge 2500 4x4 cc lb 12V auto 3.54 pillar gauges 215 nozzels
31'TT at 8000 lbs
94 explorer
New "O" Rings but reused the caps & lines as they were only a year old one tank ran dry last week & the elec pump went dead so I pump a mech on, ran OK before could my filter be pluged? now it will start then die.
31'TT at 8000 lbs
94 explorer
Ya think, last week she ran fine then she ran out of fuel & hasn't run for S%%% since.
What do you mean, "ran out of fuel"?
Do you think the problem occurred when the fuel was coincidentally low?
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
Builder what I was wondering in my fevered lil' noggin was since it didn't do this before that maybe it was conected to the sucking the front tank dry. Since then she just hasn't run for long even after I figured that the elec pump was bad & put a mech one back on, so I was wondering if maybe the filter is the problem?
31'TT at 8000 lbs
94 explorer
It could be a small leak or just some air in the return lines to the tank. The thing with your truck is that if you run the tank dry it allows the return line to get air in it especially if you leave the truck to sit for a bit before filling up. If you have dual tanks it'll do the same thing but usually after a little bit of cranking you can usually get it to start. If after a tank or two of fuel it clears up that's probably what was causing the problem. A quick tip for dual tanks is only run your tanks to about 1/4 empty and then the return line can't get any air in it...though on long trips I'll usually run them down until the gauge reads "E" as even there I still seem to have about 6 gallons left in the tank and then I make sure to fuel up before shutting my truck off at the end of the long trip.
And that's my 2 cents.
__________________ 1992 F350 7.3 Liter IDI Four door long bed 4x4 5 Speed Manual ZF. Future: ATS Turbo, John Deere green paint job, gear vendor overdrive kit, Herculiner for the bed, and WVO fuel kit. Also 1990 F250 7.3 Liter IDI two door supercab with 5 Speed Manual ZF planning to sell after I pull my cd player, CB radio, and slider back glass out.
George after a few tries it will restart but shortly dies agian, just started it today she ran for about 6 minutes before it began to surge a little bit then died. going to pull the filter next before starting her should it be full of fuel?
31'TT at 8000 lbs
94 explorer
hmm strange...not sure I can help out much more I've never run a tank dry just had hard starting with low fuel. When you pull the filter off though it should definitely be full of fuel.
Just for s&g's started her just now & she ran for 9 minutes before starting to surge then died did not try to restart.
I just came back from the garage and found that my 6 way valve is stuck and not transfereing fuel cprrectly. The front tank should only have 5 or 6 gallons and she was full. They are going to replace the 6 way with as new one tommorrow and maybe that will correct my stalling.
Might be your IP, I'm replacing my 2nd one now with the same symptoms. Fires right up but then dies, if you hold yours to the floor can you get it to stay running? Mine will sometimes but putting in a new IP shortly here.
