My batteries are getting weak. Time to replace them.
The previous owner put in Delco Group 24 675cca marine starting batteries. (Lasted 7 years, so I can't complain.) However, the battery trays look like they take Group 27 batteries.
What are the stock battery specs (and size)? Whatever I put in, I want to be sure the specs exceed stock.
Bob Bills
KG6LMV
Orange County CA
1987 F-250 XLT Lariat, 4x4, Reg. Cab, Longbed,with Callen camper, 137,000 miles. Normally aspirated 6.9 with Hypermax cowl induction, Racor fuel filter. C-6/1356 tc/GearVendor/4.10 posi/33 BFGs. Stanadyne in tanks and Jeep in tow.
A lot of us are using the Wal-Mart Maxx batteries (65N) They're about the best price, have a 3 year free replacement warranty, and seem to hold up pretty well. They're also rated for 825 CCA if I remember right.
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
FYI 850CCA is the bare minimum per battery, Wally mart has 1000CCA I believe pretty reasonable. Don't get confused by seller gobledygook as to CA (cranking amps) and CCA (Cold cranking amps) this is probably one time where more is better.
EDIT Do check the cable conditon closely.........
My truck is a Group 65, If you go to the many websites you will see competitive batteries at 850CCA.
Sams Club under $50 each
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
I just replaced my batteries after have a hard starting winter..
I bought Group 65 batteries from my local CAT dealer. 1100CCA $70Kanuk each.
I also replaced ALL my cables. 2xGround and positive. larger wire than stock and cleaned the areas to ground. $150Kanuck (built my own with parts from the Freightliner dealer (they had cable in stock)
What a difference!
__________________ 92.5' F-350 XLT RegCab 7.3l IDI N/A
2" Lift 35"x12.50x16.5 Continental M/T's
Manual 5 speed
3.5" downpipes to the Y 4" Straight Piped exhaust
<font color="blue">Beautiful British Columbia,</font> <font color="red">Canada </font>
2001 Ford Explorer Sport Trac
4x4, 3.73 Gears, HID Lights,Black
1986 Toyota Pickup 4x4, Reg cab longbox
33 x 12.50 M/T's, Smittybuilt Bumpers, Offroad Lights, 3' Body lift, Autometer Sport Comp Tach, 86 Supra Buckets, Also Black.
I put 2 Group 31 1125 CCA in mine. They just fit into the battery box's. Only trouble that I had was lifting them over the fenders, they are heavy. I'vs had them in for 3 years now and never had a slow start yet.
444-4D I just checked your Tulsa weather it's 64.5 in Tulsa .. Well here it's -4 and snowing .. You can probably use 500 - 700 CCA batteries year around (maybe not even use the block heater) but I'll keep using my 1040CCA batteries
1992 F-350 , CC , 4x4 , 7.3 IDI , E4OD , 3.55 Gears , 130000 KM , 4" Lift Kit , Altezza Tail Lights , Euro Clear Headlights ,1990 F150 Chrome Front Bumper, Xenon Extreme White 80/100 Bulbs , E4OD Transmission Cooler , Sony AM/FM /CD /MP3 /XM Ready , Insten FM Digital Transmitter , Apple Ipod video (60g) , Rancho RS5000 Shocks , 10X16 Americal Racing Wheels , 315 LT /75R 16 Durango XTR Radials..
And what has that got to do with the quesion that was asked?
The original poster had an '87, I think they switched from 27 to 65 somewhere around in there, maybe someone knows exactly when.
