Stock Superduty Turbo on 88'IDI - Diesel Forum - TheDieselStop.com
Old 07-03-2009, 04:35 AM   #1 (permalink)
JASTECH's Avatar
My Photos: (16)
How do I fit a stock superduty turbo on an 88 IDI? What will I need? Is it possible?
Thanks, JASTECH
1988 F350 7.3L Diesel Crew Cab 5spd, 195k
1980's F250 Cab w/doors, Dash, New Pw/Brk Booster,
sanded and primered Grey For Sale BO
2005 Nissan Xterra OR
1973 International Scout II
Chevy 350 30over, 4-Bolt main, SS Valves, MSD Ignition, Comp 9000 Dist, Edelbrock Manifold/Carb,
4" Suspension & 3" Body Lift, Dana Front/Rear/TC, TH400 w/Stage 2 kit, 33x12.5x15 BigO Mud tires.
1973 Jeep CJ5 (Project)
http://www.earlycj5.com/forums/showthread.php?t=59609
JASTECH is offline
Old 07-03-2009, 07:27 AM   #2 (permalink)
it's possible,but it's a custom-fab job, not a direct bolt-in.
M.L.S.C. is offline
Old 07-03-2009, 10:53 AM   #3 (permalink)
88beast's Avatar
ya youll need to fab up all the pipes youre self
im going to run both pipes up the drivers side of the motor
may work for you too
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 07-03-2009, 04:24 PM   #4 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
It's possible, but is a much larger turbo than what our IDIs will need.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Old 07-03-2009, 06:56 PM   #5 (permalink)
JASTECH's Avatar
My Photos: (16)
So will it harm our IDI's or do we just turn the turbo down a notch?
88beat, WHen you do yours maybe make a 2nd set for me too?
Thanks, JASTECH
JASTECH is offline
Old 07-12-2009, 05:50 PM   #6 (permalink)
drinkypoo's Avatar
My Photos: (10)
Lots of people have said don't run more than 11 PSI. The compression is really high on these motors. That's what the ATS 088 maxes out at (no wastegate, that's just what it goes to.) If the PS turbo is wastegated, you should be able to set it just fine. It will probably cost you more than buying a used ATS though.
1992 F250 XLT 4x4 Super Cab 7.3 IDI E40D 3.55 ATS 088 4"R.C 373k
drinkypoo is offline
Old 07-13-2009, 12:50 AM   #7 (permalink)
JASTECH's Avatar
My Photos: (16)
It is a Non-Wastgated Turbo so should be fine then. I am looking forward to the extra umph when needed.
Thanks, JASTECH
JASTECH is offline
