ok now that i got the motor some info on it
7.3 idi out of a 94 truck stock turbo motor
it may have 2 bad injectors (i will rebuild or replace)
i do know it has a knock on the 3rd cylinder on the drivers side
its more of a tick than a knock
i think its a valve issue from hearing it so heres the plan im ging to pull the head and take a look for damaged valves today (i hope the motor is covered in oil and idk if the place that pulled it drained the fluids) so when i get the head pulled ill add some pics
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
now a question for the members
whats the rocker ratio im looking to upgrade the pushrods but idk how to get new better rockers those stamped ones are weak and seem to be a main limiter of the motor
im looking for a billet one you see on race gas engines i just need to know how to measure it
ya itll be posted on here along with the install
how do i tell the ratio? rod to center to valve?
I have been working on swapping on roller rockers and just havent devoted time to it. Making some money has gotten in the way of r&d.
They are 1.5 ratio.
Mahle makes replacement pistons that are already shorter tops to lower compression.Mahle was the OEM for the pistons, best ones available.
PSD rods are not the same.
Here is the list of what I have done to my engine
Sleeved 2 bad holes and bored 20 over, coated low comp pistons,rods bushed and bored about 8 thou shorter to lower comp more, coated bearings ,rockers, pivots. Torque cam. bronze PRP valve guides, the best there is IMO, inconel exhaust valves, new springs are mandatory. Polished ports,balanced bottom end.Block decked 4 thou, heads 5. ARP studs for the heads.
New melling oil pump. NOT recommended. Check out the original, if it is in spec, re use it. Polished and shimmed the oil relief, they get sticky after many miles.
I had to remachine mine to get the clearances in spec, the melling rep said they cant check them all, nice attitude. Cermakromed the exhaust parts to keep in the heat for the turbo.
91 F350 crew cab 4x4 7.3 ats and intercooled with cut down 2000 ps cooler, bigger turbo comp,head studs, torque cam, coated rockers , balanced. very good power.
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. type 4 2840 turbo fi, lots of fun
thanks for the info typefour
im going to reuse all the original parts i can that are within spec
i still need to calculate the comp ratio so once i do then ill know the pistons i need
hope that stand works for ya. i had same style one rated for 1200 lbs. bent with the weight on it. didnt truck it. made my own.
PLAY TRUCK
1986 F250 6.9,ATS turbo, np435, BW1356, hp 60,welded up sterling 10.25.
converted from 2wd to 4x4
sittin on 36x12.5 goodyears
GETTING CONVERTED TO SHORTBED AS WE SPEAK!
according to the file I have saved the 93/94 7.3 IDI has 21.5:1 compression stock.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
stand will be fine im giong to pull the heads first and still support it with a 2x4
anyone know the tranny bolt size? i need to pick some up to hold it
i know thats the compresion chuckster thanks though
i meant the new compression ratio because i want to run twin turbos on it like the new superduty on the same pipe
i think na it will need to be around 19.5-1 then at first turbo (always spinning) 20-1 then 21-1 or so with the second kicked in
progress sorry no pics too dark to take um today
i took off the intake and pulled all the gps and injectors
the cylinders all look pretty good from gps no oil and no swelling except on one cylinder but it was an autolite gp so im not too concerned
injectors were all pulled before i picked up the motor (not sure why) and they look ok but dirty
Yeah I realized what you meant after I posted and thought about it. I did give you the formula for figuring it out right? I am getting antsy to see some pics here...
ya pics will come son i got a better camera and im picking up the bolts and puling both heads hopefully tomorrow
right now theres not much to take pics of yet so its in the waiting till i get free time
update i pulled a head tonite the drivers side and took lots of pics i will post tomorrow now im going to bed
i got the drivers head pulled and i cannot get the vally pan out it seems to be stuck where the oil drain from the turbo is any tips?
