updates updates im getting there i got more pics that ill throw up tomorrow
i got heads off valley pan out and now is where questions start
theres white crusty buildup on the pistons and valves what is it?
and a slime on one cylinder what will cause this too?
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
That way I can have a good look at it. Could be calcium from water (coolant) leaking into the cylinders. Slime might be algea from fuel that sat in the cylinder. How long has the engine been sitting around?
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
This will be a great thread to follow. Dont think im brave enough to pull my engine apart. Hopefully I wont have to for a while.. Keep posting the pictures.
Thanks Vinnie
1994 F-350 7.3 IDIT, Dually crew
C6, Gear Vendors Over/under drive unit
Roll along package, Alcoa wheels
2001 Airstream 30' S/O 70th Anniversary
Air-safe hitch coupled to a Reese Dual Cam
Thanks Vinnie
If you ever have to...I am not the least bit leary of tearing into one of these things. After a Dodge V10 these are a piece of cake
How did your airstream gathering go?
vinnie get a apare like mine the beast is a daily driver and if this motor works out how i want then itll be a 300 hp daily driver
new pics being added as we speak the white stuff is a crusty stuff almost like a thin layer of pumice and the green slime is goopy and nasty but it wipes off very easy
once i got the other head off i could see that at the rear of the vally pan there was a bolt holding it on
i scraped off the crud and used a 3/8 drive extention to get it out
where does that hole go though?
it looks pretty deep
motor has been sitting around for a week or two thats all so no big deal there
the slime is im not sure what it is but it hasn't grown i know that
im thinking calcium too there cause the head gaskets weren't in too good of shape
i need to know the head gasket thickness
the piston cc
the combustion chamber cc
and the deck height of these motors thanks
anyone ever hear of john deer injectors in these engines?
Never had, but wouldn't surprise me. Did JD ever use this engine for any of their equipment ? That would be my only guess whey JD would have built injectors for it.
Then again, they probably would have been the same injector as all the other IH motors as I wouldn't think they would build their own and just stuck their Logo on the packaging.
All speculation I guess. You'll have to call a JD dealer and see if they come up with anything.
Here's something for ya, I have no clue though the dimensions, but they sure look similar in mechanical design.
THE BLUE BOMBER! Currently Toast !!!!
87 ford f-350 cab-chassis dually. 2wd, 6.9, 3 speed C-6. 3 leaf helper springs, 11,000 gvwr, pintle/ball hitch, 6 pin round trailer connector (unhooked currently). Rear generic truck stop lights. Twin I beam front end with coil springs. Plow lights and switch to go from headlights to plow lights. 8.5 foot meyer diamond plow with central hydrolics. 8 foot rugby dump bed. 167,000 miles and still strong. Solid State Glow Plug Controller.
yepp homework for the night winner gets to see my engine when finished at an idi rally
i am going to look into the injectors next time im down by the dealer they have locally
