update i started cleaning the heads
now to paint them im thinking of die grinding them fairly smooth to make it look better any opinions on this?
the white crud and the carbon cleans off pretty well
i posted some pics let me know what you think
ps if anyone is wondering the exhaust manifolds will bolt up on reverse sides
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
yes, exhaust manifolrs will bolt up on the other side, they will just point up or forward.
PLAY TRUCK
1986 F250 6.9,ATS turbo, np435, BW1356, hp 60,welded up sterling 10.25.
converted from 2wd to 4x4
sittin on 36x12.5 goodyears
GETTING CONVERTED TO SHORTBED AS WE SPEAK!
ya ive seen it asked a few times so i wanted to throw it in here as a fyi
where's the pics? maybe go easy on the die grinder as it might gouge the surface and then oops!!! I have been known to use a sander, it may take a little wihle but it doesn't gouge..
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
all on the link still too much effort to resize and post here i only added a few though soon ill have a turbo mock up once i dig the holset out of storage
update on the motor
heads are getting cleaner
painted part of the block
and ridge reamed a few of the cylinders
block will be green
and heads im thinking blue
im also considering using allen key bolts on everything to look cool
only issue is i cant get the harmonic balancer off the crank how i do this?
Yep, you need a harmonic balancer puller. Basically a cast block of metal with slots in it. Long bolts go thu the slots into holes in the balancer where the pulley bolts up. Then a larger center bolt is turned to pull the balancer off. Typically you remove the crank bolt, remove it's washer and reinstall it to protect the threads so the big bolt on the puller and push against it if I recall correctly. I haven't pulled a balancer in about 5-6 years. On some pullers the center bolt is small enough to fit inside the crank bolt hole I think. Check and an auto parts store, you should be able to rent it.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
man that sucks ill just buy one cause my buddies didnt work for it and work got um on sale dirt cheap now
hey stroker when you get youre tires see me ill try to get you a deal
well im going to run around 19 or 20 -1 comp thias will allow a 100mm turbo at least
Yeah the way I look at it is if you have the money to buy a tool that you need for something you might as well buy it and not rent it because chances are you're going to need it again. That way you always have it at least. Thanks 88, I'll give ya a shout when I need new meats. The way im burnin these off, won't be long!
1989 F-250 4X4 C-6 7.3 IDI, 4.10 SRW, Cobra 148GTL, 4ft bed mounted whips, 12" Powerbass sub, 600W Powerbass amp, Sony Headunit, GPC override(thanks M.L.S.C), Factory Ford aluminum rims from OBS PSD, 4" exhaust, no soupbowl, B&M shift kit
20+ psi boost im not sure till i fully get all the parts im digging the holset out of storage this weekend
im debating the size of the second turbo should i use a stocker or smaller?
i think smaller than stock will limit flow
I don't know how the stock compares to Bank's turbo, but it seems like you'd need to go larger than stock. Back to the comprssion issue... I'm not sure if compression is limiting boost on the IDI or the turbo is limiting boost. I think 12lbs. is about all I ever got out of the Bank's turbo
'02 Ford-350, 7.3L!!, 4x4, CC, 3:73's, straight 4" exhaust(early exit), Edge Evolution programer, Charcoal grey exterior and two-tone grey interior, 308,000 miles and counting
'83 F-250 w/ 7.3L(toasted), 4x4, 3" lift, Bank's Sidewinder, Dark Metallic Blue
