hey guys i have a 1990 f-350 4x4 and well jsut bougth a 91 f-150 2x4 partstruck. the body on it was perfect. i was wonderign if i swap cabs will i have to switch all the wiring out of one cab and install into the other cab or is there provisions to using same wiring and hook it up to diesel?
thanks,
jimmy
1993 f-250 7.3 banks turbo 3inch downpipe into 4 inch strait pipe and 4inch tailpipe comign out at 45 degree angle under bumper on passengerside. fuel cranked up Runs great!
*Current project*
1990 f-350 4x4 when bought had tons of problems and also had no tranny ot transfercase
4 speed tranny, transfercase installed, new injectors, advanced timing like it should be, new voltage regualtor, has meyers plow, new clutch master cylinder, I have wiring problems with it right now on the interior guages
I would "think" you will need to switch the wiring....
im not sure about all wiring but i know the wiring for the ignitiona dn the wiring that runs down your steering column is interchangable, when i bought my truck last year the ignition was broke and i took a steering column out of a gasser and checked the plugs, and they connected and havent had a problem yet. im not sure about all wiring but i would guess some does and some doesnt.
jabink89
1986 f250 Lariat 4x4 6.9L c6 auto/285-75-16's/ brand new viper red paint with my own custom interior viper red and black to match body/front flare out fenders to match newer body style bed from a 95 (custom)
my current project
1985 f250 4x4 in the process of getting her ready for a 12 valve cummins swap.
Mr roboto, could you explain what the fss and the gp is? I am new to the forum and doing my first gas to diesel swap. We are going from 5.0 to a 7.3 idi in a four door 91 bronco. I have installed the engine already and am wondering if I was going to have to swap the harness from the donor truck.
gp is glowplug and you will neeed to swap the harness and you will be happy to get rid of all the the emissions junk under there
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
Yeah i'm doin this same cab swap this summer... the cab i'm using is from a 94 f250 to a 90 f350 tho... i'd assume the wiring is the same as the older style---atleast i hope it is.
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jbronco</div><div class="ubbcode-body">Mr roboto, could you explain what the fss and the gp is? I am new to the forum and doing my first gas to diesel swap. We are going from 5.0 to a 7.3 idi in a four door 91 bronco. I have installed the engine already and am wondering if I was going to have to swap the harness from the donor truck.
Sorry to hijack you thread fordman. </div></div>
Fuel Shutoff Solenoid and Glow Plug Solenoid. They get their power from the same wire and are the only things you need power to for the motor to run.
There is really no need to switch any harnesses. There are many more wires in a gasser harness than a diesel harness. You just need to run a switched ignition wire to the FSS and GP circuit. I doubt both those solenoids together draw as much power as a gasser ignition does.
