Per the dummy gauges, the truck has been charging at the "L" of normal and the other day it was above that. So I put my voltage meter on it while sitting in the driveway, nothing on, and it is charging at 15 volts +/- (hard to tell with my meter). This can't be good for the system. Any way to adjust the regulator? If not, what could be the cause?
Re: System Charging at 15 volts + - can i adjust it?
Thats about where my dumby gauge is too, sorry can't help you.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
Actually depending on system conditions you may be ok. Example a weak or a dead cell or two in a battery will make for a higher charge rate. As well as temp, engine rpm etc. I would check the bat's.
88 F 250 7.3 Super Cab XLT Lariat4X4...Cream Puff
81 Corvette...Pampered
Harley Shovel 88" Show Stoper...WOW
BBC 468 Jet Boat...Gotta get Wet!
It's the Women that cost me the $$$$
My truck also reads that high.Been that way for 5 years.Diesel tech at the dealer said it was normal...I have had zero problems with the batterys or charging system.......well except when the tensioner broke and wrapped the serp belt around the fan 5 times and left me stranded..oops wrong story
Cory
1992 F250 XLT 4x4 reg cab 7.3 na auto.120,000 miles
285/16 BFG AT,16x8 allum rims
Banks Y pipe to 3" stainless/flowmaster with 4" stainless tail pipe.
Stainless over axel traction bars w/stainless axel brkts.
Stainless upper and lower F/axel spring brkts.
Stainless sway bar links and brkts.
Powerstroke bumper insert
Firestone Air bags (rear)
stacked plate trans cooler with gauge
Temro resirculating block/water heater
Rancho RS9000 shocks
Allum box liner
1936 Diamond T 212bd
1968 Mustang FSTBK 427 4 spd
1967 Mustang 289 5spd
Originaly member #8410
How accurate is your meter is the question I would be asking... Over time all meter will get out of calibration and your not that much higher than I have seen on The Enterprise or other trucks.
Travis
Will Work For Diesel Fuel.
14-15 volts is ok. It takes a higher voltage than the nominal 12 volts to get the batteries to charge.
Yup, Jim's right. The old gasser's voltmeter runs at 14-15 volts all day long. If it drops down to 12 or less, then I know I'm not charging and there is a problem. The factory "gauge" (and I use that term loosely) gives no useful info. Scrap it and install a voltmeter. That's what I'm doing on my project truck.
Heath
__________________ 1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
