Old 12-19-2005, 04:47 PM   #1 (permalink)
Tach going Nutty
Hi everybody.
I am having trouble with my factory tach on my '93. Sometimes it registers, and sometimes it doesn't. It bounces a bunch.
Is the probably culprit the tach sending unit located in the timing gear cover? I noticed that one of the two wires appears to be loose right where the wire goes into the sender.
Is this a dealer only thing, or can I find it at Napa or Kragen?
Thanks a bunch in advance.
Bill
1993 F250 4x4, Extended cab with a 7.3L IDI, 3.55 axles, 5-speed manual, Hypermax Turbo, 3.5" Hypermax exhaust, No soup bowl, a K&N filter, and a newly installed RDT. Hoping for an intercooler install soon. 152,000+ miles and counting.
bgfire is offline
Old 12-19-2005, 06:07 PM   #2 (permalink)
Re: Tach going Nutty
that's it. It's a dealer item, $50.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 12-19-2005, 06:08 PM   #3 (permalink)
Yep, probably is the tack sender (located by the oil filler cap, get one from the stealership. Lucky you have a standard, if it was a auto the trans would be going into limp mode, hard, erratic shifts etc.
deanj is offline
Old 12-19-2005, 06:09 PM   #4 (permalink)
grt
Hi everybody.
Bill
If the wires are loose thats likly the problem. BUT, you might want to try cleaning the unit first. Just take it out, use a little wd 40 or similar and a paper towel and put it back. It helped my tach a lot and it only took about 5 min.
91 ext cab, 4x4, 5spd, 3.55 rear, soup bowl removed, ~190k
grt is offline
Old 12-20-2005, 12:50 AM   #5 (permalink)
Thanks for the help guys.
I figured it was probably the sender. I will check it before I get a new one, but it will probably be a trip to the stealership soon. [img]/ubbthreads/images/graemlins/frown.gif[/img]
Thanks,
Bill
bgfire is offline
Old 12-20-2005, 12:04 PM   #6 (permalink)
check out this post
Clickey
1989 F250 7.3 N/A 2wd bone stock finally fires in the cold!!!!!!!!!!!!!!!!!!!!
dont miss out ***************
Proud BOOB man http://p087.ezboard.com/bmidatlanticforddieselclub
dbarilow is offline
Old 12-20-2005, 12:13 PM   #7 (permalink)
My Photos: (17)
When you get the new tach sensor in, tape the leads up so that it is stiff and zip-tie the leads to something solid. The wind from the cooling fan blows on the leads and we all know what happens to copper wire if it is bent back and forth a zillions times an hour. OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
