Tach HELP?? - Diesel Forum - TheDieselStop.com
Old 04-10-2008, 08:11 AM   #1 (permalink)
Tach HELP??
Hi, I have a 91 model 7.3 installed in an 86 F350. The 6.9 I took out had the tach sensor on the injection pump drive gear cover. On 7.3 I can not locate the sensor. I looked by the oil filter housing and did not see it. Do I need to swap the pump drive gear and cover? Thanks Steve
71swinger400 is offline
Old 04-10-2008, 08:37 AM   #2 (permalink)
mm
Yep, need to change the cover for one with a tach sender mounting.
1992 F250, 5 speed, extended cab, replaced 7.3 with 6.9 2-5-08
DewEze round bale carrier
mm is offline
Old 04-10-2008, 01:00 PM   #3 (permalink)
Some how I knew that was the answer.
