Old 07-31-2006, 06:48 AM   #1 (permalink)
My Photos: (22)
Tach not always working ..?
This last week the tach doesn't always work .. I tested the sensor and it tests good .. I tested the fuse and it's good (but the other gauges on that fuse work) ..
I wouldn't be worried except when the tach isn't working the transmission (E4OD) goes (and stays) in high,to take off you have to pull it into low and shift manual ..
1992 F-350 , CC , 4x4 , 7.3 IDI , E4OD , 3.55 Gears , 130000 KM , 4" Lift Kit , Altezza Tail Lights , Euro Clear Headlights ,1990 F150 Chrome Front Bumper, Xenon Extreme White 80/100 Bulbs , E4OD Transmission Cooler , Sony AM/FM /CD /MP3 /XM Ready , Insten FM Digital Transmitter , Apple Ipod video (60g) , Rancho RS5000 Shocks , 10X16 Americal Racing Wheels , 315 LT /75R 16 Durango XTR Radials..
truck1
truck2
ThePunisher is offline
Old 07-31-2006, 07:34 AM   #2 (permalink)
Re: Tach not always working ..?
Replace the tach sensor. The wires going into the sensor go bad. Should be about a 50 dollar item.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 07-31-2006, 09:12 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Check all the connections, there are a few including the main engine harness connector on the drvrs fender. Are the wires at the top of the sensor bare if so they will short out.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 07-31-2006, 11:07 AM   #4 (permalink)
I agree, replace the sensor. There's no sense ruining your transmission over a $50 part. Once you have a known good sensor, that will positively confirm or deny the original being bad.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 07-31-2006, 02:31 PM   #5 (permalink)
My Photos: (49)
the tack has a connector on the back that plugs into the circuit board,sometimes over time the contacts get corroded and must be cleaned ....robert
1989 ford f-250 4x4, new DAS remanufactured 7.3, zf 5 speed- 410 gears, 600.000 + miles,hypermax turbo+exhaust system, air lift air bags all the way around,luk single mass flywheel,york on board air compressor and tank,recaro leather bucket seats,spray on bed liner, holly red pump,coolent filter,gear vender,filtration solutions oil bypass filter,ford motorcraft glow plugs,mechanical gauges in the stock cluster, mean green starter,hypermax cowl air induction system,vormax fuel filter, grover air horns,evans coolant,baja block drains.
Pictures: http://photos.thedieselstop.com/show...1&si=robertleo
robertleo is offline
Old 07-31-2006, 06:10 PM   #6 (permalink)
My Photos: (22)
I have a new tach sensor with taxes it was $99.80CDN but I didn't put it in yet ... The sensor in it is less than a year old ,and tests 2530 ohms (good is 2000-3000 ohms) .. I checked the firewall wires cleaned some with contact cleaner and put dielectric grease on them .. Also cleaned the wires on the back of the dash assy ,Ford made a cheap circuit board when they made that it's just flexable plastic.. Anyway it's working now but it worked sometimes anyway so I guess I'll have to watch it and see if it stops working again ..
I have some Ford paper manuals & CD manuals they tell how to test tach but they don't go far enough in breaking the tests down..
truck1
truck2
Old 07-31-2006, 09:08 PM   #7 (permalink)
Well if your transmission is acting funny then it's not just your dash tach that is reading weird. The tach in the instrument cluster gets its signal from the E4OD computer. If the transmission is Blinking the OD light when it's not working then it's losing it's connection before the computer, not after.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 08-01-2006, 06:31 AM   #8 (permalink)
My Photos: (22)
The OD light isn't blinking .. I tried to find a schematic of the tach system ,but no luck finding it yet ..
truck1
truck2
Old 08-01-2006, 09:12 AM   #9 (permalink)
My Photos: (5)
My bet is on the tach sender - been down that road before. Now as for the flexible circuit board being cheap... you got that backwards... I worked in a factory that made PCB's and the flex boards are actually more durable over the long term in a much boarder range of climates and environments plus a flex board cost TONS more to manufacture... So you should be impressed that Ford actually spent the extra money and used logic to choose the flex - this is not the norm for ANY of the big 3
Travis
Will Work For Diesel Fuel.
argve is offline
Old 08-01-2006, 01:44 PM   #10 (permalink)
If you go to http://community.webshots.com/user/tim94f250 there will be a diesel tach schematic and the PCM connector. If that doesn't help, let us know exactly what you need. Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 126K
tim94f250 is offline
Old 08-06-2006, 08:47 PM   #11 (permalink)
Where is the tach sender located on a 7.3, with 5speed? Mines not working at all.
www.offroadohio.com
1993 F-450 7.3IDI N/A ZF-5
offroadohio is offline
Old 08-06-2006, 08:57 PM   #12 (permalink)
Tach sensor should be in the same place on all IDIs. It's on the injection pump cover, looks like a bolt sorta with wires coming out the top.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 08-06-2006, 09:50 PM   #13 (permalink)
Should be just to the right of the oil filler cap if standing in front of engine and on top of the IP gear cover.
1991 F-250 HD, Lariat XLT, 1 ton, extended cab, 125,000 miles, 7.3 non-turbo V8 diesel, E40D auto trans, 2 wheel drive, air, power everything and it works!
mdkarle is offline
