Tail light wiring - Diesel Forum - TheDieselStop.com
Old 01-17-2013, 03:05 PM   #1 (permalink)
Tail light wiring
So i got a new bed on and was goin to hook up the tail lights and some clown has cut the connecter off and the wires are colored different so I could really use a wiring diagram thanks
1990 f250 4x4 e4od 7.3l idi
Turbo ip turned down tq screw
315/75r16
3in lift
K&n air filter and home made ram air
5in stack straight pipes
165,xxx mi (I think/hope)
Large tranny cooler
16-18mpg
Soon to be turbo'd with nice cold air and wraped exhauste be for turbo
Rustyshackleford is offline   Reply With Quote
Old 01-17-2013, 03:08 PM   #2 (permalink)
is the truck harness cut from tail lights or just the one going to the trailer plug?
1999 f350 7.3 6spd; 243k miles no mods
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
tickedoff36 is offline   Reply With Quote
Old 01-17-2013, 03:40 PM   #3 (permalink)
The bed harness is cut like if you we're to pull your bed off the plug that connect the tail lights to power plug on the frame the wires are not the same color tho
315/75r16
3in lift
Large tranny cooler
16-18mpg
Old 01-17-2013, 09:22 PM   #4 (permalink)
you can use a test lite to find each circuit. put one of the tun signals on and probe each wire to see which wire has power, write that color wire down and proceed to the next circuit. for ex. blue wire w/ white stripe goes to? red wire? goes to? and so on. this will take a while so be patient. when you get all your wires idenified then you can prceed to connect them. this way might be better tha a wiring digram in case someone might have crossed something. if you are still having problems PM me with the wire colors and we WILL get this figured out. also the guage. i have delt with a few trucks that had to be rewired because of some nutjob that thought they 'knew' what they were doing. good luck!!
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 01-18-2013, 10:42 AM   #5 (permalink)
315/75r16
3in lift
Large tranny cooler
16-18mpg
Old 01-22-2013, 10:31 AM   #6 (permalink)
Ok so I got blinker reverse and running lights no brake lights this is all the wires matched up
Except the white and red that's only hot when I turn on switch (like running lights)
315/75r16
3in lift
Large tranny cooler
16-18mpg
Old 01-22-2013, 02:17 PM   #7 (permalink)
if the wh/rd stripe is only hot with lite sw then that could be your tail to trailer. do you have a 3rd brk lite? you can chk color with that and possibly match up. in the pic what color wire is the other one? are those ALL the wires? how easy is your fuse box to remove? find the right fuse and flip the box over and see if you can match OR your switch on the pedal. it might be possible to have tail and brake switched. are your running lites dim or bright? the brake is brighter than tail. disconnect your tail and tie into the wht/red st and chck and get back to me.
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 01-22-2013, 02:28 PM   #8 (permalink)
All the wires from the bed have been used my cab brake light isn't working so there's something wrong with that I'm goin to check fuse and all that good stuff
315/75r16
3in lift
Large tranny cooler
16-18mpg
Old 01-22-2013, 07:35 PM   #9 (permalink)
worse case run a new wire from front 14gauge that way you'll have xtra for trailer.
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 01-23-2013, 11:35 PM   #10 (permalink)
Got it all working was just a fuse for the brakes but the bulb is out on the top of the cab
315/75r16
3in lift
Large tranny cooler
16-18mpg
Old 01-24-2013, 12:34 AM   #11 (permalink)
glad you got it working!!!
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
