Tapping/Knocking noise
Hey guys,
Got a few things going on with the ole truck. I've started to notice a tapping sound (it seems little too high pitched to call it a knock) from the motor. It does it usually pulling away from a stop sign, and goes away at around 1500 rpms (give or take a little). Also, and this started about the same time, first thing in the morning shakes pretty bad, and blows a bunch of blueish smoke out the exhaust. The smoke goes away after a few minutes or so, but the shaking comes and goes througout the day at stoplights and low rpms. Sometimes it will idle smooth, and sometimes it will shake. It did this a few months ago (the shakin, not the smokin), and I replaced all the injectors and it ran perfect, I mean like a new motor, for about a week. My main concern is the tapping right now, even though they are probably related, I'm just afraid if its coming from the bottom end (bearings), or would that be a deeper knock. Any suggestions?
Thanks, Ben.
1994 F-350 XLT Crew Cab, SRW, Factory Turbo IDI, E4OD, 3.73 gears, 223K miles.
2000 F-350 Crew Cab
