Im just a little curious about something, dont have the funds at all to get into my elbows (yet)
When cruising my temp guage barilly hits the N in normal, (i know the factory guages suck) But as soon as i let off the pedal, or coast down a hill it drops about 3/4 way down to the line. (not the C, but the first bar past it) This kind of seems to me like I need a thermostat. The truck warms up nicely and gets REAL hot inside when the heat is cranked. It has done this eversence ive owned it (Sept. 2005) so in warm weather it does the same. NEVER gone past the bottom of R in normal, only twice have I gotten that warm, and that was towing up a real good grade, about 1/8 mile before the top, and gettin outt of a MUDDY cornfield.
Im not conserned at all, just curious what u guys think, does it need one or not??
My truck
* 1992 F-250 supercab XLT 4x4 7.3 auto 3.55 open rear 170K miles, Westin Nerf bars, Silvania Silverstar headlight bulbs (VERY NICE!) Mile Marker SS hubs, piped, cranked and cut! Dimondplate toolbox, Pioneer cd player. And 16-18MPG backroad/town/highway driving!
Friends truck
* 1988 (originaly) F-250 regular cab 7.3 C-6 auto 4x4 4.11 posi rear.
Custom mods: Dana 60 front, ZF-5speed, Banks Turbo kit with Boost, Pyro, and Oil Temp, F-350 Badging, 93 front clip, F-150 Lightning seats (oh those are nice seats!) CD Player, 2 10" subs, custom 4 inch exhaust, soon to be 5" stacks! Turned up IP
Ford makes it, International shakes it!
First thing to do is get a REAL mech temp gauge, not a electric, in it. You do not want to over heat these puppies, and the OEM gauge is nothing but an 'idiot gauge'. You absolutely cannot believe anything it shows. Post back when the new gauge is in, and we'll go from there if necessary. OkieGringo
Ok, thanks gringo, I appreciate it. She deffinatly isnt running hot. (at least sure doesnt feel like it! [img]/ubbthreads/images/graemlins/phoney.gif[/img] ) When I bought it back in Sept. it had, had the waterpump, New 4 core Rad. and fun clutch all replaced VERY recently, (along with Batts, and starter, hehehe)
Now, you said Mechanical, Im not familliar with plumbing a mechanical guage. Am I going to have to run acctual coolant tubing inside the cab? Where is the BEST place on the motor to get the best reading? Thanks Gringo!
My truck
Friends truck
It's real similar to an electric, but it has a very small hollow copper tube which will be coiled up when you get. Uncoil the tube VERY carefully so that you don't pinch it off. You just run the tube thru the firewall, usually from the engine compartment into the cab to wherever you mount the gauge. On mine I put the probe in the drivers side head where the original "idiot gauge" was. The only OEM gauges that I watch are Fuel, Tach, Speedo. OG
But what's wrong with say an Auto Meter electrical temp gauge? Are they unreliable?
I won't say they're unreliable. Electrical connections can come loose or corrode at the most inopportune times. Do what you want [img]/ubbthreads/images/graemlins/shrug.gif[/img]. OG
Sure, anything can fail, even little coolant tubes [img]/ubbthreads/images/graemlins/smile.gif[/img]. I was just wondering if you'd had a particular bad experience.
1991 F-250 7.3l IDI, ZF-5, 2wd, 3.55 gears, Pioneer PEH-3500 Stereo with XM Radio, Infiniti 5 1/4" speakers
Yes, back in the old days, the electrical was off by 10 degrees. Maybe they're better now. I'll let you be my 'guinea pig' [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. OG
I have a similar temp reading on my truck and it's been there for about three years. If I start on a trip, the temp will gradually move up to just below the "N". Once I stop and then restart, my temp guage will go over to the red zone and stay there for sometimes another hundred miles. If again, I stop it will drop back to normal. It's unpredictable when it will happen but un-nerving when pulling my RV on the inter state.
I've removed the sender and cleaned up the probe and it still does the same thing. This Spring, I am going to go through the coolant system and replace the thermostat, hoses, etc. I also had an earlier Ford that did the same thing and at that time I did replace the sender and it did cure the problem. This time, I am more inclined to replace the thermostat as it's behavior seems to indicate a sticking problem?
1994 F250 HD, IDI Diesel, 3:55 gears, K&N filter, Hayden Tranny Cooler, Monroe HD SensaTrac shocks, dual pillar pod with temp & tranny guage, poly fuel tanks
Thanks Gringo I think im going to go with the electric. When I get some dough, or if Ive been a good lil boy this year Santa just might bring me some Autometer guages and a tripal guage pillar pod for christmas! hehehe [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
My truck
Friends truck
