Old 01-27-2006, 08:53 PM   #1 (permalink)
thermostat
wheres the thermostat on a 93 n/a? is it under the metal thing that the rad hose connects to behind the alternater.
93 f350 5 speed cc long bed 4x4 162,000 mi 4 inch lift 35" tires.
76 early bronco in resto.
southern oregon on the coast brookings
cams76 is offline
Old 01-27-2006, 09:13 PM   #2 (permalink)
My Photos: (23)
Re: thermostat
we have a winner! pick a prize from the top shelf.
use the Ford stat for best results. part# (with gasket) - E5TZ 8575 C
make sure the checkball in that housing is moving freely upon re-assembly. it'd be a good time to add a coolant filter & Baja drains.
Frank
Unofficial BOOB man (unofficial BUTT division: brotherhood of un-turboed trucks)
meet Big Black, my 1992 International 3/4 ton pickup wrapped in a Ford skin: 2wd, LWB, N/A 7.3, ZF5, 3.55s. 249k miles.
Amsoil bypass & AF. 3" true duals. no soup for me. 'ghetto' fresh air. Baja block drains. bottle broke. slobber tube. true dual 3" straight pipes. now a TRUE oil burner - she's drinking 15% Bunker Fuel (WMO).
soulpatchfr is offline
Old 01-27-2006, 10:26 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: thermostat
Cam since you don't like PMs here is some info......
CAUTION:
The specified/required thermostat does not contain an internal bypass, since the bypass is located in the cylinder block. Whenever the thermostat is replaced, it is mandatory that only Motorcraft E5TZ-8575-C or Navistar 1807974C94 thermostat be installed.
CAUTION:
Do not attempt to repair any thermostat. It should be replaced if it is not operating properly.
Check the any new thermostat before installing it for correct opening temperature. Before suspending in boiling water, with a flashlight check where the rubber and the flat metal flange meet for bad seal. Tstat should start to opening barely at 180-192f, fully open 200-212f, allow to cool and check for rubber seal again.
Removal: Disconnect batteries, drain 4+ gals A/F, remove: as required, fan belt, alternator set aside, alt bracket, remove filter support from fuel filter then e/block. Disconnect upper rad hose at rad, remove tstat bolts and housing. Clean both faces, depression and holes in block, ensure check ball in goosekneck is clean, free and rattles "do not remove".
Installation is reverse proceedure, I do not use sealant on gaskets and faces. REMEMBER the tstat pellet(copper end) goes into the block. I do use a "very small amount" of sealant on the edge of the tstat face when installing into the recess, now go for coffee, allow sealant to setup, this has saved me from tstat slippage when the gasket and goosekneck are installed. Replace all items in reverse order......
Manifold bolt torque......... 20ftlbs
Proud Canadian BOOB man too!!
cdnsarguy is online now
