Old 03-31-2006, 01:47 AM   #1 (permalink)
Those dang glow plugs
Ok, I'm no diesel mechanic. I've replaced 6 of the Delphi's the PO had put in. Any tips or tricks to gettin in the back 2 GPs on the passenger side? This is the factory turbo. Short of taking off the turbo and the air housing, I don't see how I'm going to get this done - talk about tight spaces!! I took off the air housing for the driver side, but it looks like the turbo might have to come off for these last 2 babies. I don't have a decent manual for the diesel either - so please chime in - how do you guys accomplish this small feat?
Silver Liner
1994 F-250 XLT Supercab 4x4, 7.3 IDI Turbo; E4OD sometimes getting the blinking O/D. Loaded options. 4 prior owners.
Reinstalling '93 OEM 31" radiator.
Regularly tow 6x12 trailer @ 2500 lbs, loaded.
2050 rpm @ 65 mph.
18 mpg hwy. (Up from 14 when bought)
Currently use Power Service.
bcreighton7 is offline
Old 03-31-2006, 02:53 AM   #2 (permalink)
Re: Those dang glow plugs
i hope you are replacing the ol delphis with motorcraft/berus. Only use m/bs cause others can and will swell and tips will break off.
Go to a local autozone which seems to be the cheapest for the m/bs.
About the turbo, i dont know if there are any tricks, but somebody will followup with some more useful info.
--Ryan
91 f-350, dually, 7.3 diesel. 2wd, 4.10 gears LS. E4OD. New injectors, lift pump, and fuel filter at current 85,000 miles. Autometer pyro and fuel turned up. 3" exhaust with walker "btm" muffler
http://community.webshots.com/user/olivera_149
olivera149 is offline
Old 03-31-2006, 10:05 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
This info from another post....
You can get the back glow plugs out using a 1/4 inch drive socket, it helps to remove the injector lines and vibration clip to give yourself some room, but you do not need to remove the turbo.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 04-01-2006, 09:50 PM   #4 (permalink)
I think I was using a 3/8 deep socket with a U joint - those back two are just - well the one under the turbo you can't even see.
Now I've got a new problem. I had 6 of my berus in, and I got it to start up cold. This morning I go out and nothing - I had to put it on the block heater again. I got my neighbor's tester, and the front 2 glow plugs at least had nothing - no light when I touched the leads. Is this a reliable way to test the GPs? Seems like I remember you guys saying it's not. So now I don't know if I fried my relay, or the glow plugs or something else. I know I didn't burn them even 45 secs - certainly not straight. I've read people hook them up to a battery, and the berus will last longer than 45 secs. How would I use an Ohm meter on them?
Silver Liner
2050 rpm @ 65 mph.
Old 04-01-2006, 10:07 PM   #5 (permalink)
to get those hard ones in the back corner out with out removing anything get a mac tools long 1/4 inch extention that has a universal built into the extention and a deep 1/4 drive 3/8 socket it works like a charm.test the glow plugs with the wire conected to them with a over the wire style amp meter.most glow plugs draw around 9 amps or less but they must draw something or they aint no good.and that POS expensive glow plug realy timer thing i throw in the trash and replace it with a cheap regular old relay a high amp on like 80 or something like that you know the kind that ford bolts on the pasenger fender for the starter on all there trucks.get that kind just get a high amp one.then i wire it to a push button in the cab.works great and last a long time and is cheap.use never sieze on the new glow plugs and tighten them in with just a good little snugg there not lug nuts.with that tool and the new relay glow plugs will be a sinch for the life of your truck.
2000 f250 4x4 lariate woodland green metalic and gold on the bottom.sharp looking super cab.100,000 miles .air heater mod,CCV mod,zoodad,80 econo DP tuner PCM ,cranked doun stock waste gate,cubie hole type gauge pod,k@n replacement filter.sonax/tricumulator, map sensor pop off valve,boost tube,BTM ,code eliminators ,wiked wheel,EBPV deleat ,hp oil cross over feul presure shimed and gauge, Heater core hose bypass valve .Wet Okole seat covers with Powerstroke logo ,.home made donaldson intake in the works parts on order.mounting bracket and 45* silicone elbo.piss on this homemade thing it will never be as good as the AFE stage II.thats what i'll get next.i am curently running my stock air box
WUNDERHOOT is offline
Old 04-02-2006, 12:30 AM   #6 (permalink)
My Photos: (17)
Have you checked the fusible links in the GP circuit. They are real close to the starter relay on the passenger side fender well. To use a regular test light, hook the ground lead to the battery positive and then stick the point of the light to the top of the glow plug. If it lights up bright, GP is good. No light or dim light, GP bad (not likely with new Motorcrafts but very possible with even new Autolites). OkieG
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 04-02-2006, 12:57 AM   #7 (permalink)
Did this with the test light on the front two - of course I changed them in a pinch this last fall because they were the ones I could get to on a trip. Since then I've been running them overtime to get me started, so it's possible I did fry them. I just replaced the other 4, like 2-3 days ago, but I didn't test them, but from the sound of the engine turnover, they may be fried - that is what I don't get. My OEM relay is already bypassed. PO owner had someone do it. But they used Delphis with flat leads, so unless I change out the lead terminals, I have to use ZD-1-As instead of ZD-9s. Where can I get terminals that will work on the ZD-9s? AutoZone didn't have anything. Will I have to go to the dealer? In the mean time I will test the other 4 new berus, and let you know what I get.
Silver Liner
2050 rpm @ 65 mph.
Old 04-02-2006, 03:05 AM   #8 (permalink)
My Photos: (17)
You should be able to find blue bullet crimp-on connectors at a good autoparts store. Ya gotta "think outside the box" and not rely on those kids behind the desk. They ain't working at a autoparts store because they did well in school [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]. OkieG
Old 04-02-2006, 12:29 PM   #9 (permalink)
You already have the flat terminals and a bypassed controller. No reason to go back to Ford's bastardized system now. Buy a set of Motorcraft GP's for a 86 - down 6.9L, or get a set of these: http://cgi.ebay.com/ebaymotors/6-9L-...spagenameZWDVW
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 04-02-2006, 10:58 PM   #10 (permalink)
Well -- they're all fried - all six - 4 only used once. Don't know what the deal was, but doesn't make me particularly impressed. Will replace one more time. I did forget to reconnect the small hose to the turbo - so the engine was "smokin." I thought it was just oil I spilled onto the block - I took off the oil sender, and turned over the engine to see if I got any oil. Put it back together, and now my oil pressure gauge is working again. So I'll let you know if the GPs burn out again. If so, something is goin on.
Silver Liner
2050 rpm @ 65 mph.
Old 04-06-2006, 11:29 PM   #11 (permalink)
Could a break in one of the harness wires(about half the copper wires being broke by one of the terminals) cause enough resistance to blow the GPs?
Silver Liner
2050 rpm @ 65 mph.
Old 04-07-2006, 12:31 PM   #12 (permalink)
I doubt it would blow the gp's but it i would probably cause them not to burn as hot as they should, possible no start, fit it!
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
