Timing belt on the 7.3? - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 12-18-2009, 11:14 AM Thread Starter
Is there a rubber timing belt on the 7.3 IDI or a timing chain? My truck is wrapping the 250k mark and everything I have replaced so far was from the factory. After owning a VW diesel (and knowing tossing the Tbelt = catastrophic failure) I figured I had better ask if the 7.3 IDI uses a rubber timing belt or not.
88 F350 7.3, Z5 speed, SB Standard cab dually, 4.10's, 5" exhaust
Pre95 is offline
post #2 of 19 (permalink) Old 12-18-2009, 11:53 AM
Mark Kovalsky's Avatar
My Photos: (6)
It does not have a rubber timing belt.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 19 (permalink) Old 12-18-2009, 12:10 PM
chuckster57's Avatar
YUP!!! all gears intermeshed. nothing to stretch or replace
Train Horns:
PM please not visitor message
chuckster57 is offline
post #4 of 19 (permalink) Old 12-18-2009, 01:27 PM
88beast's Avatar
ya heavy duty diesel applications are all gear driven so no timing belt or chain
but check to see it the ip is off if you have concerns
88 f250 96 bed 95 front clip western mirrors and big ole bumper.
7.3 idi t70, 3g, g31,
other mods, oba, warn winch, big steel goodies including a headache rack etc.
check out my site at
88beast is offline
post #5 of 19 (permalink) Old 12-18-2009, 02:46 PM Thread Starter
Awesome, thanks for all the input guys, lays that worry to rest for sure.
Im not really concerned about the timing of the motor (runs good, no smoke, etc) but I am a fan of preventative maintenance and figured I had better ask.
Pre95 is offline
post #6 of 19 (permalink) Old 12-18-2009, 03:16 PM
tfenny's Avatar
Do check the serpentine belt often and replace at service interval. Tim
2000 Excursion, 2WD, Estate Green Metallic Paint, all stock 136,000 miles
tfenny is offline
post #7 of 19 (permalink) Old 12-18-2009, 04:05 PM
Plywood's Avatar
My Photos: (13)
I'm thinkin' his 88 has 4 v-belts like my 89 engine.
85 F250 XLT Lariat 4x4 7.3L N/A, C6, 315/75/16 Siped Wild Country Muds, Manual ZD9s, K&N, Soup Bowl Out, Dura-Lift Pump, Dynomax 3" Y-pipe-4" AFE Muffler-5" Turndown.
Turn it up!
Plywood is offline
post #8 of 19 (permalink) Old 12-18-2009, 04:57 PM
StrokerSmoker7.3's Avatar
yup I got the Vbelts too. Anybody know how to get the alternator drive belt to stop flopping wildly. It is as tight as it gets and still has this problem. I've heard some other people say it is a known problem and there really is no fix. Is this true?
1989 F-250 4X4 C-6 7.3 IDI, 4.10 SRW, Cobra 148GTL, 4ft bed mounted whips, 12" Powerbass sub, 600W Powerbass amp, Sony Headunit, GPC override(thanks M.L.S.C), Factory Ford aluminum rims from OBS PSD, 4" exhaust, no soupbowl, B&M shift kit
1997 F-350 4X4 E4OD 7.3 Powerstroke, 3.55 SRW. 3"DP to 4" exhaust, TS performance 6pos. chip, Quadzilla Recon XGT, DIY Tymar style intake, Atwood fiberglass cap
StrokerSmoker7.3 is offline
post #9 of 19 (permalink) Old 12-18-2009, 04:59 PM
fro
when is the service interval?
94 F250 IDI turbo e40d with 367k on her.
Hypermax exhaust,cowl induction hood and AFE air filter added
Vegas baby!!
fro is offline
post #10 of 19 (permalink) Old 12-18-2009, 05:02 PM
Plywood's Avatar
My Photos: (13)
Gotta love that one huh.
If I put a new one on I can get it tight enough to not flop, but then it seems too tight for comfort.
Turn it up!
Plywood is offline
post #11 of 19 (permalink) Old 12-18-2009, 06:06 PM
there was a guy that used to post on here--bajagringo--he mounted another flat pulley-----like a tensioner one, in the midway area on that belt to stop the flopping--if it does that bad enough--itll throw the belt
94_turbo is offline
post #12 of 19 (permalink) Old 12-18-2009, 07:38 PM
87CrewDually's Avatar
Just snapped this pic. I mounted an idler pulley to a piece of flat stock (1/4 x 2 x 4) via drilled/tapped hole. Then simply welded it to the bottom of the alt. support bracket. Took care of virtually all the slop. You don't want to run belt to tight or it will prematurely wear items and could snap once the engine warms.
87CrewDually is offline
post #13 of 19 (permalink) Old 12-18-2009, 08:33 PM
Plywood's Avatar
My Photos: (13)
Nice!
Turn it up!
Plywood is offline
post #14 of 19 (permalink) Old 12-18-2009, 08:50 PM
pontoonrob's Avatar
There is a fix for this.I put a small pulley off of one of the water pump bolts on the left hand side. The most infamous "OkieGringo" came up with this idea a few years ago.it tightened up the belt just enough that it doesn't flop around hardly at all. Maybe the post is still around.(I still have a hard time with the search feature). Someone also came up with a shorter belt #.i'll search my computer and see if I saved that post.---Rob
Cool 1988
F250,4x2 XLT extended cab,rebuilt 444cu inch,naturally aspirated IDI,5speed gearrower,aluminum radiator,facet dura lift "trans/cold"electric lift pump,99%pure virgin lead batteries,13" Sachs clutch,exhaust brake,lighted running boards,cab roof lights,! cb radio,guage whore
,dueling pyrometers,-- persons+engine+gear=6990lbs!13-19mpg.
pontoonrob is offline
post #15 of 19 (permalink) Old 12-18-2009, 10:56 PM
88beast's Avatar
stroker gimme a call ill fab you up a idler if you want its not hard and its a waste for the most part unless its really bugging you
and stroker wasnt it youre vac belt?
88beast is offline
