I put the IP on with the lines lined up, and really it runs pretty good, but when I hook up a jumper to the advance, it seems like it knocks less rather than more, as I've read here it should in several places.
Sort of sounds like an 8 cyl cummins 24V if you know what I mean, then with the jumper it seems like the rpms go up a little, and the knock is slightly less, then when I disconnect the jumper it goes back to the deeper knock sound.
I got 14.5 mpg on the last trip, which I think is pretty good for a 4.11 geared C6 4x4.
Little bit of white smoke and plenty of rattle on cold warmup idle.
Lots of power though!
Any thoughts?
85 Ford 7.3l IDI F250 XLT Lariat 4x4 4.11gears, C6, alloy wheels, manual GPs.
85 Ford Bronco, NP435, NP 208, 3.55gears, Red w/white top, I6, maybe diesel someday.
I kind of thought retarded also, but I've read here it should knock more when advanced with a jumper to the cold advance, not less, but maybe I am confusing knock and rattle though.
The IP has a Stanadyne reman tag on it, I know that it was slightly more advanced when I took it off, but I bought it recently and I don't know if it was professionally timed or what, so I didn't rely on that too much.
Think about it, if you have it retarded, and you advance it slightly to where its not knocking, then everything is normal. You just need need to advance the pump itself a bit. Sounds like you have it retarded. When you jumper the timing advance, it advances it to where the timing is supposed to be, with no knocking(so advance the pump). When I had my IDI, I Experienced some knocking on retarded timing as well as advanced, moreso advanced.
1994 F-250 PSD, 280+k and still strong, 2wd, zf5 close-ratio, 4.10 rear, Tymar intake, Valeo SMF, 205* T-stat, DIY Aux idle control,shot the cat, dual trucker antennas, 5600 pounds, matching autometer ultra lite boost and pyro. DIY stage 1's, ts 6 pos chip (stock anti-theft 50 75 100 140), excursion HFCM fuel pump on its way
Nicknamed the american bear http://community.webshots.com/user/91diesel **91diesel AKA anthony2010**
OK, so I'm retarded then,
seriously though, if that's the way it is, then that makes sense.
I've always read here that they knock when advanced, and sound flat like a gasser when retarded.
Maybe it's more like knock when retarded, and rattle when advanced?
