Timing Setting - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 08-31-2011, 02:09 PM Thread Starter
Timing Setting
I'm curious what other people have done. I replaced the injection pump a little while ago and was told to set it advanced a little to make up for wear, I have 270,000 on the engine I have the mark about .030 advanced. Having done a valve job recently do I still need to advance the timing? I still have wear on the lifters, cam, and gears, right?
I have also read that the marks are scribed after assembly so unless I reuse the original pump the lines may not be accurate? Is this right?
What have you guys done and just how close does the timing have to be?
1990 F250 Extended Cab 7.3 Non Turbo 280,000
erik49051 is offline
post #2 of 20 (permalink) Old 08-31-2011, 03:00 PM
trailscout's Avatar
I'm new and know absolutely nothing. That said, I've been reading a lot trying to solve a different problem and have read several places that the marks on the IP are just there for getting the engine started up where a dynamic timing can be done. All say that static timing will not produce a good running engine.
1989 International Box Van/FunMover conversion. 7.3L IDI w/5 spd manual.
"Within every small problem is a much larger problem desperately trying to get out"
trailscout is offline
post #3 of 20 (permalink) Old 08-31-2011, 04:24 PM Thread Starter
Thats the impression im getting from reading the different post but wnat to get everyones opinion in one post.
Thanks,
post #4 of 20 (permalink) Old 08-31-2011, 04:55 PM
My Photos: (27)
Some people aren't new and they still know absolutely nothing. You should have two sets of marks on your IP and gear housing. The ones at 12:00 position are the static marks. The second set, dynamic correct factory timing with the original IP are in about the 3 o'clock position. My dynamic marks have been lined up mark to mark since '91 when I bought the truck new. Had the original pump overhauled and calibrated years ago and I lined them up as they were before. At almost 1/4 million miles it still runs just like the day I bought it new.
Nothing that's going to really effect injection timing. In all breeds of heavy truck diesel engines I've torn down over the years I never found one with excessive backlash (wear) in any timing gears. Timing chains in gas engines are another story, that's their major internal weak point that wears out first.
LMJD is offline
post #5 of 20 (permalink) Old 08-31-2011, 06:11 PM Thread Starter
so since I put a different pump on I should have it dynamically timed, right?
post #6 of 20 (permalink) Old 08-31-2011, 06:43 PM
My Photos: (27)
I would, maybe there's an authorized Stanadyne dealer near you? They might be your best bet.
LMJD is offline
post #7 of 20 (permalink) Old 08-31-2011, 07:39 PM
chuckster57's Avatar
Specially when it's a SBC that uses the plastic teeth
Train Horns:
PM please not visitor message
chuckster57 is online now
post #8 of 20 (permalink) Old 08-31-2011, 08:24 PM
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
The GM 6.2l and 6.5l diesels used a timing chain and to compensate for chain wear you had to advance injection timing a couple degrees every 50K or so. One of mine wouldn't run well unless it was at 14 BTDC, and obviously that meant injection was taking place closer and closer to a time when the intake valve was still open.
With our gear-driven IPs, the only wear you'll see is internal wear in the pump. Get it rebuilt or replace it when hot starts become difficult and you'll never have to mess with timing just to make it run smoothly, as long as it's properly dynamically timed.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
post #9 of 20 (permalink) Old 08-31-2011, 09:35 PM
My Photos: (27)
Holy Moley, I forgot about the plastic teeth era. Small block Fords too. Didn't the long lasting Ford 300 sixes use an oddball brown fiber teeth cam gear IIRC? Engine would last forever but when you drained the oil and found little fiber fragments that was a clue it was timing gear time.
LMJD is offline
post #10 of 20 (permalink) Old 09-01-2011, 07:17 AM Thread Starter
I worked at an autoparts store in the early 80's. We sold lots of timing chains and gears, but mostly for Pontiac's from what I remember, that had plastic gears. I seem to remember that the replacement was plastic too?
post #11 of 20 (permalink) Old 09-01-2011, 09:59 AM
Bill1013's Avatar
Since you have an N/A IDI, the timing should be set at 8.5 to 9.5 BTDC with the pulse timing method, like a Ferrett timing pickup. The timing is set at 2000 RPM. If a luminosity/pulse probe is used, then it's done with a 20* offset. You also have to have a good digital timing light. Timing is done on #1 or #4 cylinder. The line on the damper has to line up with the 0 on the timing plate.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #12 of 20 (permalink) Old 09-01-2011, 10:37 AM
My Photos: (27)
Right, but I think aftermarket offered steel cam gears and HD chains if you wanted them. Years ago a horse trainer I ran around with would always buy 3-4 quarts of oil and add along with ever tank of gas in his badly abused Chevy 350 without even checking the level first. I finally checked it out and his timing chain had gotten so worn and sloppy it had actually worn a small hole through one side of the timing cover, that was where the oil was going. His idea of mechanical preventive maintanance never went beyond Ivermectin Horse Wormer.
LMJD is offline
post #13 of 20 (permalink) Old 09-01-2011, 11:15 AM Thread Starter
Bill1013, how much did the equipment cost to check the timing? Ford wants $288 to check and adjust.
post #14 of 20 (permalink) Old 09-01-2011, 01:40 PM
drinkypoo's Avatar
My Photos: (25)
Nissan KA24E has plastic timing chain guides and when they fail the timing chain will saw through various parts softer than it is if they are not replaced. But the timing chain is not considered a service item...
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #15 of 20 (permalink) Old 09-01-2011, 01:44 PM
Since we're getting off the topic, Fords V8's with the two timing chains have four guides that are some sort of plastic and make a mess of things when the chains stretch. Seen it twice in the last 6 months.
Train Horns:
