Tip that could help when engine @ operating temp
It seems every time I go to adjust FIPL, check timing, fuel return lines etc., I've got a really nice heavy duty steel step stool, but, I have scars on my stomach from the hood latch & I've gotten a few mild burns from the radiator in the same place.
being vertically challenged & under tall for my weight [img]/ubbthreads/images/graemlins/biggrin.gif[/img] I came across the idea of using a heavy duty mud flap 3/8"-1/2" thick and lay it over the radiator & that hood latch, much better.
Every time I see one on the road or by a construction site I stop and pick it up, (free is nice).
Hope this idea helps the brothers out.
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system.
http://community.webshots.com/user/jl_mendoza
