Hi everybody,
I ended up getting my IP installed and timed (thanks cdnsarguy for all the advice) but seemed to uncover many more problems.
1. My IP got gummed up a bit and wouldn't provide fuel to the engine. I thought it was a lift pump and since it I was in a parking ramp, I thought it best to have it towed to the nearest repair shop that I trust.
Turned out that the IP governor or fuel regulator was rusty and stuck shut. (on a new reman none the less)
They got it started but found what sounded like a dead miss. I believe it because a mechanic friend pointed it out himself awhile back.
It could be either valves or rings or both I guess at this point so I must ask the question.
If I have to have either my rings or my valves replaced or possibly both would I just be better off getting a new engine? I imagine that this would be very expensive of a repair for a shop to make. I can't think that they would just replace the rings on just one cylinder, or just one valve you probably replace those in a set right?
How much would a complete overhaul cost if I did it myself? what would I have to send out for (block cleaning and boring) and what could be done by myself? Any special tools needed to get the job done right? Has anybody heard of renting an engine stand? How much time for an experiences mechanic to do this (id probably take three times that much)
I guess im pissed at myself because this is just becoming a real money pit. I've already put 1600 into this thing and now this
Do any of these kits look good?
International Navistar 7.3L Early Engine Rebuild Kit
https://www.northernautoparts.com/Pr...d=1297#options
Thanks for all your help.
