trailer tow relay
i recently had to replace the headlight switch. i also had to to splice in a new connector as the original had melted. anyway, i am going to do the relay mod for the headlights and found some are doing the relay mod for the trailer taillights also. while rooting around in the engine compartment, i found a relay on the driver side fender marked trailer tow. its right next to the vacuum canister. i tested it and found that turning on the headlights activated it. so, my question is when did ford use the relay, maybe the mod was for older fords, and should i still do the taillight relay mod.
-03 6.0 f350 lariat crew cab long box 4X4: SOLD!!!!
-new truck: 90 f350 xlt lariat crew cab long box 4X4, 7.3 n/a- will be adding boost asap, just have to rebuild the 093, soup bowl mod and k&n for now, e4od-soon to be zf5, posi 3.55s, headlight relay mod, poly front/ rear swaybar and track bar bushings, monroe reflex shocks, let the poweradding begin
-87 turbo t we4 w/ astro roof
-05 chevy uplander-momma's
