Old 08-02-2006, 03:19 AM   #1 (permalink)
tranny guys..
ok, so my 93 idi has lost it's overdrive... seems to go through 1'st 2nd and drive fine but no od. you can hit the button all ya want but no change. the off lights not on or anything, i'm sure it's probably a sensor or something but where do i start my search? dont know if this is a common problem with the e40d trans or if i'm assed out and need a rebuild...many thanks in advance for any advice you can give me...
www.sandwizards.com
93 f250 extra cab 4x4 7.3 idi
stone stock except coolant filter
96 f350 crew cab conversion dually 4x4 7.3 psd
k&n/lund visor/alcoa's
01 f350 crew cab 4x4 7.3 psd
k&n/centurion package
bansheeboy is offline
Old 08-02-2006, 07:47 AM   #2 (permalink)
Re: tranny guys..
If you are not locking up the T/C you are over heating the trans fluid. If a sensor goes out on these trans they go into failure mode, do not drive for any length of time (normally burn out the clutches in the T/C). Get the codes read (drivers side near the firewall on the fender is the connector). You need the FIPL, VSS and tack working correctly for the trans to shift. The other place you may want to look at is the solenoid pack connector, they get oxidized over time and the pins do not make good contact.
deanj is offline
Old 08-21-2006, 01:35 AM   #3 (permalink)
Re: tranny guys..
figured i'd update, ended up being the wires in the gear selector arm. i talked to my tranny guy and he said to swap the arm and low and behold it solved my problem. i opted to just swap out the arm/button and trim ring instead of trying to salvage the button and ring off the old one but all is well now. he also said if the od was not engaging then the trans was just running as if the od was switched off and if it were a problem then you would tear up your t/c just by hitting the off switch...makes sense to me...
www.sandwizards.com
Old 08-22-2006, 02:56 AM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: tranny guys..
Heavy tow loads..... Ford advises to take it out of OD to save the trans from damage.....
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 08-22-2006, 08:12 AM   #5 (permalink)
Re: tranny guys..
Can you show where Ford says that? I have never found that in any of the many owner's manuals that I've read.
Casey_1 is offline
Old 08-23-2006, 12:38 AM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: tranny guys..
Give me some time and I will find it.......many moons back we had a Ford Trans engineer on here who was extremely knowledgable and he was always refering to that info.......
Old 08-23-2006, 01:39 AM   #7 (permalink)
Re: tranny guys..
I just bought a 92 F250 7.3idi s/c auto 2wd. The truck is in excellent shape with 110,000kms. The trans seems to shift okay when unloaded, but with my 26' 5th wheel, it seems to upshift from 2-3 too quickly. Sometimes within 1 second of the 1-2 shift. It is like the trans is sensing too easy of a tow and it just upshifts. The obvious result is "instant bog" and loss of speed while I react to it and try to regain the lost MPH. I can hold it in 2 manually, or if I step the pedal down, it will down shift back into 2, but it really is anoying. Is there some aftermarket "Tow/Haul" accessory which could be installed, then activated via a switch on the dash to hopefully adjust the shift points and/or characteristics when towing?
Any comments are appreciated.
Clyde
'92 F250 2WD S/C 7.3IDI Auto (E40D) 3:55 Gears
150,000km
26' Komfort 5th Wheel Trailer
munn is offline
Old 08-23-2006, 08:34 AM   #8 (permalink)
Re: tranny guys..
I remember Mark K., too, and I'm sure he NEVER said you can't tow in overdrive.
Casey_1 is offline
