Tranny Swap Questions - Diesel Forum - TheDieselStop.com
Old 11-04-2009, 07:03 PM   #1 (permalink)
El 'Jefe's Avatar
My Photos: (5)
Send a message via Yahoo to El 'Jefe
Will a six speed manual from a 7.3 PSD bolt onto a 7.3 IDI? Also, does anyone know the gear ratios from this trans vs. the ratios from a ZF5 Manual trans...The reason i ask is that if the six speed is strung out a bit farther, i would like to lower my rpms for economy purposes while maintaining the power i would lose with a taller rear end gear.
93 7.3L idiTurbo, LWB, 2WD, Crew Cab,ZF5, 4.56RearEnd.
Soon to come:Garrett Dual Ball Bearing T3/60-1with 3" V-band DownPipe Flange on a .63 turbine housing and a 4" compressor inlet,11lbs wastegate, Garrett High Performance Intercooler, 4'' downpipe to a 5'' exhaust all the way back. All on a sesame seed bun.
Don't Worry...I will take Pictures.
El 'Jefe is offline
Old 11-05-2009, 10:51 AM   #2 (permalink)
osufireman's Avatar
Here's what I found out with some searching online and on the forum:
ZF6 ratios
Low 5.79:1
First 3.30:1
Second 2.10:1
Third 1.31:1
Fourth 1.00:1
Overdrive 0.72:1
Reverse 5.23:1
Standard gear ratios on the ZF S5-42: 4x4 and 4x2
Close Ratio
1st Gear:
4.14
2nd Gear:
2.37
3rd Gear:
1.42
4th Gear:
1.00
5th Gear:
0.77
Rev Gear:
3.79 Wide Ratio
1st Gear:
5.72
2nd Gear:
2.94
3rd Gear:
1.61
4th Gear:
1.00
5th Gear:
0.76
Rev Gear:
5.24
The ZF S5-42 main case cast number is “1307”
Standard gear ratios on the ZF S5-47:
Close Ratio - 7.3L Diesel
1st Gear:
5.08
2nd Gear:
2.60
3rd Gear:
1.53
4th Gear:
1.00
5th Gear:
0.77
Rev Gear:
4.66 Wide Ratio
1st Gear:
5.72
2nd Gear:
2.94
3rd Gear:
1.61
4th Gear:
1.00
5th Gear:
0.76
Rev Gear:
5.24 The ZF S5-47 main case cast number is “1317”
As to whether a ZF6 will bolt up to a 7.3L IDI
Here's a link I found on a nother TheDieselStop thread about zf5 to zf6 swap, a writeup that one of the other members did on his swap experience. ZF5-ZF6 swap
1990 F250 XLT Lariat, 4x4, E4OD, 4.10 rear, Twin Traction Beam, NA 7.3L IDI. 225K miles
osufireman is offline
