Old 05-02-2005, 09:36 PM   #1 (permalink)
My Photos: (24)
trans fluid
i just replaced the boot and cover assembly on the tranny i have (zf-5) and i noticed i need to add a little fluid. i allways used motorcraft atf dextrom and mercon compatible. wath do you think if i add some of that lucas stop slip tranns fluid just to help? is it good, neccesary, better? any other product that you'll add instead?
thank you, exekiel
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 05-03-2005, 09:46 AM   #2 (permalink)
Re: trans fluid
Id didn't any feedback from TDS members when I was looking for suggestions. A bud of mine that maintained a fleet of Ford trucks for many years specifically said synthetic ATF in the ZF (Mobile1 Full Syn. ATF = $5/qt.) or the dealer supplied "special ZF lube" ($20/qt.)...
FWIW, the Mobile1 seems to have made a difference in the shifts...meaning the synchros seem to fall right in line now... YMMV [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
'92 F250 4x4 Reg.Cab LB/7.3L IDI w/ PS filter&RotellaT @ 178K
ZF w/ Mobile1 syn. ATF
TTB&10.25FF with4.10s
B&W+Tenkosha"Voyager"+Putnam ClassV
PRE-scratched & dented Jeep Hauler
Rented Mule
CaverDave is offline
Old 05-03-2005, 10:21 AM   #3 (permalink)
Re: trans fluid
Exekiel,
Try this stuff, I use it in almost everything that moves & has metal.
http://www.militec-1.com/automotive1.html
Also, this result from adding Militec to the engine:
http://www.militec-1.com/curts11.html
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system.
http://community.webshots.com/user/jl_mendoza
jlmendoza is offline
Old 05-03-2005, 12:04 PM   #4 (permalink)
Re: trans fluid
Ditto! I first started using it about 15 years ago to prolong the life of some extremely hard to reach gearboxes (buried deep within the bowels of a 400' long processing machine = ULTRA PITA!)...went from 1 gearbox per week (total of 16 in that process) to 1 every 2 months!
Don't know if it's come down in price (seems a pint used to run $75USD! [img]/ubbthreads/images/graemlins/eek.gif[/img]), but well worth the price to make stuff live!
Edit: WOW! It's come *WAY* down in price (haven't purchased any in 10+ years)...will call the local rep. and see if he can still get it!
Rented Mule
Old 05-03-2005, 02:25 PM   #5 (permalink)
Re: trans fluid
Exekiel,
I've been running Red Line Synthetic in mine for about 40,000 miles now. Tranny shifts fine and is quiet as church mouse as it was making some noise in OD. Worth the $9.00 quart, in my opinion. My $.02...
Keith
93 F350 CC Dually 7.3 Hypermax turbo 4:10 gears, ZF rower, K&N filter, home made ram-air, Hypermax 3.5" exhaust, LUK clutch, 150,000 mi.
Weezer is offline
Old 05-03-2005, 05:54 PM   #6 (permalink)
My Photos: (24)
Re: trans fluid
hey this militec looks loke the best in the world, is it really that good?
so if i get it i can use it not only on the tranns but on every oil change too, right? how much do i need for a 11qt oil change?
thank you, exekiel
- 4.10 open, DRW
more pics
BOOB Man
soon..
- paint job.
Old 05-05-2005, 09:49 PM   #7 (permalink)
My Photos: (24)
Re: trans fluid
does any of you guys know how much to use for an oil change or how much for each qt of oil to use, etc?
thank you, exekiel
- 4.10 open, DRW
more pics
BOOB Man
soon..
- paint job.
Old 05-06-2005, 02:10 PM   #8 (permalink)
Re: trans fluid
exekiel,
I found this when looking around their website.
http://www.militec-1.com/directions1.html
Anyone else out there that can recommend this stuff? Seems too good to be true ya know [img]/ubbthreads/images/graemlins/wink.gif[/img]
Ryan
1988 F250 Supercab, 4x4, 7.3 IDI, C6 Auto, 147K miles
Banks Sidewinder non-wastegated Turbo, Stage 1 Injectors, and Pyro, Boost and Water guages.
My Gallery
analog is offline
Old 05-06-2005, 03:40 PM   #9 (permalink)
Re: trans fluid
Exezial, the lik that they pasted above are the same as the instructions on the 16oz. bottle, I generally get together with a guy at work & we buy a case at a time (12-16oz. bottles) $185 http://www.militec1.com/miva/merchan...ategory_Code=1
or here http://militec1.com/miva/merchant.mv...16OZBOTTLESPEC (2-16oz. bottles $55) It's great stuff, you can Really tell the diference immediately on folding knives, guns, and a little bit longer for our trucks, made my tranny last longer when it started to get really sick last year before bloeey [img]/ubbthreads/images/graemlins/vomit.gif[/img], You can also add it to the radiator to lube the water pump.
And NO, I don't know anyone at militec or make any money from recommending it, it works good for me, & looked at the technical data on sheer factor and other reports they had on their web page, and decided it would be good for me.
jerry
Old 05-06-2005, 09:04 PM   #10 (permalink)
My Photos: (24)
Re: trans fluid
i receibed 2 16oz bottle today and i added 6oz to the tranny. i hope it will be good to maintain it in good shape. i drove it a little this evening so far no difference, anyway my tranny have not given me any problem so far.
now about the engine oil, if i use the recomended motorcraft i still have to change it every 3k miles right. cause on the back label of this bottle said's to do so but also said's add every 15k miles [img]/ubbthreads/images/graemlins/confused.gif[/img].
any help appreciated, exekiel
- 4.10 open, DRW
more pics
BOOB Man
soon..
- paint job.
