Transfer case problems....no high range. - Diesel Forum - TheDieselStop.com
Old 03-06-2005, 11:24 AM   #1 (permalink)
Pulled the Jeep down to Richmond last night and stopped there before heading out for some wheeling today. Was manuvering the truck and trailer in a tight parking lot, and had put the t-case in low range (didn't lock hubs) just to keep from slipping the clutch so much.
I later took off to go across town (t-case shifter back in 2 high) and got to 3rd gear and the t-case slipped out with a very slight grind. tried shifting from 4wd to 2wd high, and still not moving. whenever it slips out of high range, you have to put it all the way back in low, drive for 10-20 feet, the put her back in high....and it only lasts for about 100 yards then slips out again...
anyone else have this problem? i've been into a million Jeep chain driven cases, so i'm going to attempt to tear into this one, but didnt' know what exactly to look for. i'm assuming that if there is a range fork it is working properly, since it does go into low range.
i dunno.
any help appreciated.
Conn [img]/ubbthreads/images/graemlins/phoney.gif[/img]
New rig: 1995 Dodge 2500 LB, Reg. Cab, 4x4, Cummins, 3k GSK, Hillbilly plate ground, 4" exhaust, 285/75/16s
Old rig:
1989 F-250 7.3 IDI, 4x4, 4" Rough Country Lift, Hypermax Turbo, 128K, 5 Speed, 4.10 gears, Custom air intake, "MIG-Made" Propane Kit, 3.5" Dual Chrome Stacks w/ straight exhaust, 285/75/16 tires on Classic 589s, Pioneer MP3 Player with 10" sub, Galaxy DX959 CB. Savin' some bread for some new 315/75 shoes.
My drinking team has a rockcrawling problem.
Hold it 'til the valves float!
nosliw is offline
Old 03-07-2005, 06:37 AM   #2 (permalink)
Re: Transfer case problems....no high range.
Yep had this problem, the shift fork has some nylon pads on them and they wear out, it's not a big job to replace the pads or do as I did and replace the whole fork. I got a new fork off E-bay for $25. Good luck......... Jim
<font color="blue">[b]93-F250 (Super Duty), Extended cab, Long Bed, XLT, Gray & Black, 7.3L, New Injector Pump, New Injectors 4X4, ZF5 5 speed trany, 4.10 gears Limted Slip.</font>
<font color="red"> Click here to check out My $800 Texas Truck</font>
<font color="green"> My 30 ft Wilderness 5th wheeler after new paint job and striping.</font>
<font color="purple"> The 2004 IDI rally in July</font>
<font color="red">Life, Liberty and the Pursuit of All Who Threaten It </font>
ltl_jrw is offline
Old 03-09-2005, 11:11 AM   #3 (permalink)
got a call from the tranny shop this morning. the pump went out, got hot and welded itself to the main shaft.
GRRRREEEAAATTTTT.....
anyone want to buy an 89 IDI with no transfercase? [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Old rig:
nosliw is offline
