The proper hose is "transmission oil cooler" (TOC) hose. It will be marked on the casing along with possibly the SAE J1532 spec. The diameter is usually 11/32" but it is available in 3/8" and 5/16" as well. Fuel line isn't meant to take the heat and pressure
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
