Old 03-20-2005, 07:35 PM   #1 (permalink)
My Photos: (9)
Transmission grinds in reverse
when i bought this truck it would grind into reverse occasionaly and you would just have try again and it would always go in second time. Over the short time that ive had this truck its gotten worse, i was having to put it in 1st then reverse and would go in, now its at the point where it just wont go in. i have to literaly turn my truck off then put it in reverse and fire it back up. If i sound fired up its because it happened about 20 minutes ago so i got all pissed and filled my neighborhood with the nice diesel black smoke did 80 down a near by street and came back and parked it. anyway... what the hell is wrong with my tranny, Syncros? Not a tranny mechanic. Help please!
--Jon
2007 Dodge 2500 Quad Cab 4x4 SWB 5.9 Cummins 6 Speed SLT- Muffler delete pipe, removed emblems, 315/70 17 BFGs
**Sold**2000 F-250 CC 4x4 PSD Lariat 210K UT Orange W/Black- 3 1/2" straight pipe exhaust to a giant 6'' diam. 3ft chrome echo pipe, Zoo-Dad Mod, AFE Stage 1 Intake, Edge Evo., turbo timer, Powder coated black wheels wrapped with 305/70 E Nittos, 05 Conversion w/silverstars, 05-07 emblems, Color matched handles, Ranch Hand Rear Bumper, foil wrap delete/polished up-pipe, Kenwood 7100 Nav/DVD, Pioneer amp, 2 MTX 10s.
**Sold** 92 F-250 SC 7.3IDI N/A 2WD ZF5 160K "The IDI Stroker" 7.3 IDI bored .40 over w/ported heads and lots of other stuff.
http://photos.thedieselstop.com/show...0/ppuser/46803
www.mobilewheelrepair.com
jonmercer05 is offline
Old 03-20-2005, 08:12 PM   #2 (permalink)
Re: Transmission grinds in reverse
It isn't the tranny. It is your clutch. The clutch pedal gets lower and lower as time goes by (from wear on the clutch) until you can't push the clutch in far enough to release the clutch. You can crawl under the truck and look in the inspection cover on the bottom of the clutch cover and see if you have fried the throwout bearing. If not, it is time to investigate a new clutch. There are many here who don't use the stock DMF setup for cost reasons. A single mass flywheel works better, I am told.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 03-20-2005, 09:26 PM   #3 (permalink)
is there loose up fore and aft play in your clutch pedal? There is a bushin inside the clutch master cyl pushrod where it connects the pedal. It wears out then becomes metal to metal. the clearances increase and effectively you are pushing the pushrod in worse and worse. Being a 92, with x# of miles it's a possibility, some have utilized a small heim joint to replace the eylet/pin/bushing combo.
96 F-250 4x4 crew cab, 7.3l, E4OD, 140k on engine,20k on trans, ?miles on chassis....for sale now.
93 F-350 4x4 cc, 7.3L IDI, Banks sidewinder turbo, 5spd zf, 290k mi......$500 what a steal
77 f-150 short box, My mud racing truck. 429ci, c-6, twin stick np 205, 38.5 boggers, rear spool and front limited slip.
75diesel is offline
Old 03-21-2005, 12:08 AM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Download the troubleshoot file for ZF 5 speed
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 03-21-2005, 12:14 AM   #5 (permalink)
towcat's Avatar
there's no syncros in reverse.
they are straight cut gears. If your clutch is going out, then your gears are still spinning when you are trying to get in. check your oil level in your tranny too. sometimes low oil level will make it tough to get into gear.
86 f250 6.9IDI, 4spd 4X4 "the runt"
89 f450 rollback carrier 7.3IDI, ZF5, 4X2(in memory of...)
90 f450 conventional towtruck 60"CA 7.3IDI, E4OD, 4X2
92 f350 CC 7.3IDI, ATSturbo*intercooled*, ZF5, hydrostop, 4X2 "the nebuchadnezzar"
...Quack Quack................*P.A.K.*...
red pill or the blue pill? make your choice and pm me.
7/03 mini meet pics
towcat is offline
Old 03-21-2005, 09:16 AM   #6 (permalink)
I am not too sure about NO syncros in reverse. I could be rolling and hit reverse just like first gear. No grinding at all. No way to double clutch it for reverse while rolling forward.
Dave
Old 03-21-2005, 10:21 AM   #7 (permalink)
Mine does the same thing and I don't know why yet. My clutch is fine, hardly even broken in. I suspect damaged reverse idler gear or damaged reverse gear or bent shift fork or nylon pad worn off the shift fork. Next time I pull the tranny I am going to split her open and have a look. [img]/ubbthreads/images/graemlins/shrug.gif[/img]---MUCH LUCK!!!---ENUS
1991 F350(7.3IDI),ZF 5 SPEED,170000 MILES 410 REAR AND 1987 F250(6.9IDI),ZF 5 SPEED, 200,000+MILES,355 REAR.
ENUSYELLSAW is offline
Old 03-21-2005, 12:55 PM   #8 (permalink)
I forgot to mention, mine seems to go into reverse just fine without grinding. But, when I let the clutch out it grinds and pops out of gear. [img]/ubbthreads/images/graemlins/shrug.gif[/img]---ENUS
Old 03-21-2005, 01:19 PM   #9 (permalink)
You're describing exactly what mine did before the heim joint mod, which completely fixed everything for under $6
1994 F-350 4x4 Crew Cab, 7.3L I.D.I. turbo, 5 speed. So close to the Mexican border that on a quiet night you can hear the splashing of the "swimmers" and the snoring of the Border Patrols
ltwombat is offline
Old 03-22-2005, 09:52 AM   #10 (permalink)
ITwombat, what is the heim joint mod and how can I get some info on it [img]/ubbthreads/images/graemlins/confused.gif[/img].---ENUS
Old 03-22-2005, 10:58 AM   #11 (permalink)
Enus,
Check this thread Thread
93 F350 CC Dually 7.3 Hypermax turbo 4:10 gears, ZF rower, K&N filter, home made ram-air, Hypermax 3.5" exhaust, LUK clutch, 150,000 mi.
Weezer is offline
Old 03-22-2005, 01:08 PM   #12 (permalink)
Weezer, the thread won't work [img]/ubbthreads/images/graemlins/confused.gif[/img]. Maybe it's archived or something [img]/ubbthreads/images/graemlins/shrug.gif[/img]. Thanx for trying!---ENUS
Old 03-22-2005, 04:27 PM   #13 (permalink)
Too many "http//" try this.
Cotton - '93 F350 CC DRW 7.3 NA E40D 2WD 4.10, Hypermax Turbo, Intercooler and 3 1/2" exhaust, DPS Turbo Cal Pump and Stage 1 Injectors, Holley Red and more to come!
'99 Damon Challenger 31RL 5'er Generac 55G
tuckerd1 is offline
Old 03-22-2005, 07:15 PM   #14 (permalink)
Yes, that one works great! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]THANX------ENUS
