when i bought this truck it would grind into reverse occasionaly and you would just have try again and it would always go in second time. Over the short time that ive had this truck its gotten worse, i was having to put it in 1st then reverse and would go in, now its at the point where it just wont go in. i have to literaly turn my truck off then put it in reverse and fire it back up. If i sound fired up its because it happened about 20 minutes ago so i got all pissed and filled my neighborhood with the nice diesel black smoke did 80 down a near by street and came back and parked it. anyway... what the hell is wrong with my tranny, Syncros? Not a tranny mechanic. Help please!
--Jon
It isn't the tranny. It is your clutch. The clutch pedal gets lower and lower as time goes by (from wear on the clutch) until you can't push the clutch in far enough to release the clutch. You can crawl under the truck and look in the inspection cover on the bottom of the clutch cover and see if you have fried the throwout bearing. If not, it is time to investigate a new clutch. There are many here who don't use the stock DMF setup for cost reasons. A single mass flywheel works better, I am told.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!! http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
is there loose up fore and aft play in your clutch pedal? There is a bushin inside the clutch master cyl pushrod where it connects the pedal. It wears out then becomes metal to metal. the clearances increase and effectively you are pushing the pushrod in worse and worse. Being a 92, with x# of miles it's a possibility, some have utilized a small heim joint to replace the eylet/pin/bushing combo.
96 F-250 4x4 crew cab, 7.3l, E4OD, 140k on engine,20k on trans, ?miles on chassis....for sale now.
93 F-350 4x4 cc, 7.3L IDI, Banks sidewinder turbo, 5spd zf, 290k mi......$500 what a steal
77 f-150 short box, My mud racing truck. 429ci, c-6, twin stick np 205, 38.5 boggers, rear spool and front limited slip.
there's no syncros in reverse.
they are straight cut gears. If your clutch is going out, then your gears are still spinning when you are trying to get in. check your oil level in your tranny too. sometimes low oil level will make it tough to get into gear.
86 f250 6.9IDI, 4spd 4X4 "the runt"
89 f450 rollback carrier 7.3IDI, ZF5, 4X2(in memory of...)
90 f450 conventional towtruck 60"CA 7.3IDI, E4OD, 4X2
92 f350 CC 7.3IDI, ATSturbo*intercooled*, ZF5, hydrostop, 4X2 "the nebuchadnezzar"
...Quack Quack................*P.A.K.*...
red pill or the blue pill? make your choice and pm me. 7/03 mini meet pics
I am not too sure about NO syncros in reverse. I could be rolling and hit reverse just like first gear. No grinding at all. No way to double clutch it for reverse while rolling forward.
Dave
Mine does the same thing and I don't know why yet. My clutch is fine, hardly even broken in. I suspect damaged reverse idler gear or damaged reverse gear or bent shift fork or nylon pad worn off the shift fork. Next time I pull the tranny I am going to split her open and have a look. [img]/ubbthreads/images/graemlins/shrug.gif[/img]---MUCH LUCK!!!---ENUS
1991 F350(7.3IDI),ZF 5 SPEED,170000 MILES 410 REAR AND 1987 F250(6.9IDI),ZF 5 SPEED, 200,000+MILES,355 REAR.
I forgot to mention, mine seems to go into reverse just fine without grinding. But, when I let the clutch out it grinds and pops out of gear. [img]/ubbthreads/images/graemlins/shrug.gif[/img]---ENUS
You're describing exactly what mine did before the heim joint mod, which completely fixed everything for under $6
1994 F-350 4x4 Crew Cab, 7.3L I.D.I. turbo, 5 speed. So close to the Mexican border that on a quiet night you can hear the splashing of the "swimmers" and the snoring of the Border Patrols
Weezer, the thread won't work [img]/ubbthreads/images/graemlins/confused.gif[/img]. Maybe it's archived or something [img]/ubbthreads/images/graemlins/shrug.gif[/img]. Thanx for trying!---ENUS
__________________ Cotton - '93 F350 CC DRW 7.3 NA E40D 2WD 4.10, Hypermax Turbo,Intercooler and 3 1/2" exhaust, DPS Turbo Cal Pump and Stage 1 Injectors, Holley Red and more to come!
