Re: truck box
I think they're all the same from 1980-1996, i know the cab lines are all identical. As for mounting holes, I'm not sure. I wish I knew what year box I got when I acquired my truck so I knew more, but I figure if the external shape is the same, there's no real reason to change the bolt locations...
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
