truck wont start after sitting - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 09-01-2008, 11:40 PM Thread Starter
91 7.3 non turbo. Truck wont start after sitting for more than 6-8 hours. Has to have a shot of ether. Brand new motorcraft gps, voltage at the gps, relay is clicking, fresh alt. I am using jumper cables from my cummins dodge to get enough power. I can crank all day, and nothing happens.
Where should i go next.
bigwhitehd is offline
post #2 of 7 (permalink) Old 09-02-2008, 04:53 AM
Snotzalot's Avatar
My Photos: (5)
Does if fire once then die and won't fire again? Or dies it NOT fire at all after sitting?
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is offline
post #3 of 7 (permalink) Old 09-02-2008, 12:57 PM Thread Starter
it does not fire at all. runs fine once it has been run for a little while.
post #4 of 7 (permalink) Old 09-02-2008, 02:49 PM
hesutton's Avatar
My Photos: (30)
Sounds like an air/fuel leak. All that cranking will eventually bleed the air out of the fuel system and it will run. Once you park it for a while.....air leaks back in and you have the same problem.
The most common site for air/fuel leaks tends to be the injector fuel return caps/lines. However, a fuel leak can occur anywhere in the system.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter,
. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
hesutton is offline
post #5 of 7 (permalink) Old 09-02-2008, 02:51 PM
Snotzalot's Avatar
My Photos: (5)
Air in the fuel will usually give you an immediate fire and then die. Any visible leaks around the return lines?
Regards,
post #6 of 7 (permalink) Old 09-02-2008, 05:30 PM
Cjhstang's Avatar
stick a clear piece of tubing from the top of your IP to the return line. That will let you see if you have air in your lines or not. I don't think thats your prob tho like Snotzalot said.
I'd check your starter. Maybe its not turnin fast enough. Most non starts I hear of are either air in the return lines, not enough battery juice to the starter, or starter is bad. Last two cases the starter may still spin but not fast enough.
F-350 4x4 1990
-'94 overhauled 5.9 Cummins
P7100 Injection Pump w/ 4kgsk, 60lb valve springs, Hamilton performance cam, HX40 turbo, ARP head studs, New marine pistons and injectors, FASS system lift pump
-Homemade oem & engine harness with Dual electric fans
-'92 interior; '86 front clip; '04 Hydroboosted front and rear disc brake system; Slew of autometer gauges; dual 4.25" Stacks
-Rebuilt and upgraded my E4OD - billet input shaft and T.C. Remote mount Derale dual layer trans cooler; Baumann Trans Controller and Harness
-3" Body Lift, Cut-Out Bushwacker Fender Flares with 16x10 Eagle Alloy 186 on 33's
All done in the driveway and basement...
Cjhstang is offline
post #7 of 7 (permalink) Old 09-02-2008, 05:39 PM
hesutton's Avatar
My Photos: (30)
Here's a simple test:
While someone else cranks it over, open the shraider valve on the filter head. If you get bubbles or air, but not a stream of fuel, you have an air leak.
I've had several fuel/air leaks in the past with hard starting. Mine never started then died. It just wouldn't until the air bleed out of the system. For others, they have a start then die symptom with an air/fuel leak.
Heath
hesutton is offline
