truck won't stay running - Diesel Forum - TheDieselStop.com
Old 04-07-2009, 10:42 PM   #1 (permalink)
I got a 93 f350 truck will start but will not stay running but about 2 seconds then it will die.If you try to start it back up you have to spin it over about 20 times and hold the throttle open.I have replaced gp's and injectors and wts light stays on about 12 to 15 seconds.
93 350 is offline   Reply With Quote Quick reply to this message
Old 04-07-2009, 11:08 PM   #2 (permalink)
That's a classic symptom of an air intrusion, what happens is air gets in the return lines and travels up to the fuel filter, where it drains some of the fuel off - your truck fires up on the fuel that's inside the IP, but once that air from the filter head hits the IP she dies. Two likely causes of the air intrusion are leaky return lines and a bad fuel heater o-ring, both usually easy to locate as they tend to drip some fuel while the truck is running. When you replaced your injectors, did you replace the o-rings under their return caps and the hoses and clamps for said caps as well?
M.L.S.C. is offline   Reply With Quote Quick reply to this message
Old 04-07-2009, 11:18 PM   #3 (permalink)
Yes,but I didn't buy a line kit I just found some o rings the same size at the parts store and got regular 5/16 gas line and cut it to fit.But I used hose clamps and may have tightened 1 to tight and cracked 1 of those plastic pieces.The truck starts fine the rest of the day after the first time.Do you suggest I replace all the plastic pieces and put a line kit on it.
Old 04-07-2009, 11:32 PM   #4 (permalink)
chuckster57's Avatar
I was typing the same thing when you posted..
93 350: yeah I would replace the return line system with all new stuff that is made for the IDI's. You can get them most anywhere called an "injector installation kit" Just save the copper washers since you changed the injectors. The kit can be had for about $40.00 @ Midwest fuel injection (site sponsor )
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote Quick reply to this message
Old 04-07-2009, 11:54 PM   #5 (permalink)
5/16 is too big man, we use 1/4 hose. I got parts store hose too, no issues whatsoever with it, I reused the factory spring clamps.
Old 04-08-2009, 12:47 PM   #6 (permalink)
Send a message via AIM to AlaskanWombat Send a message via Yahoo to AlaskanWombat
If you are going to change the return lines you might want to consider using clear hose. That way you can see where you have an air comming into the system.
1992 F350 XL Crewcab - 7.3 IDI with 250K+, 4X4, E04D, Dura-Lift fuel pump, Strobe, Bed Work Lights, 2 KC Daylighters (Moose Lights), CB
1999 F150 XLT- 5.4L
AlaskanWombat is offline   Reply With Quote Quick reply to this message
Old 04-08-2009, 01:42 PM   #7 (permalink)
That's a good advice, however make sure you use diesel-rated fuel hose. The other thing is that clear hose is usually thinner than regular rubber hose, so them spring clamps may not work anymore, if that's the situation replace them with FUEL INJECTION clamps of the proper size (I'm guessing those for 1/4" hose will work), they are far superior to regular worm-drive clamps but they cost about the same.
Old 04-08-2009, 10:54 PM   #8 (permalink)
Thanks guys for all the info I really appreciate it.I have a install kit ordered and hopefully this fixes my problem.
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
