Old 04-05-2008, 07:59 PM   #1 (permalink)
88beast's Avatar
turbo
this week on trucks on spike they showed a universial turbo kit
they mounted it under the bed with pipes going up to the engine bay
anyone do this and is there a diference between a diesel and gas turbo?
thanks for any help
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 04-06-2008, 11:22 AM   #2 (permalink)
7.3L F-250's Avatar
My Photos: (16)
Send a message via AIM to 7.3L F-250
you can do it on a diesel but you will have such a insane turbo lag you will hate it
-Tj
RIDES
1987 ford F-350 xlt lariat, full leather interior, 7.3L idi, banks turbo, E4OD, MBRP muffler, 6" lift, 38" superswampers for summer, 35" BFG all terrain for winter, bronze pearl paint
CURRENT PROJECTS
1979 ford F-350 custom 351m C6
soon to get a 7.3idi, ats non-waistgated turbo, 6" lift kit, Saphire blue paint, and much more
WANTS A
2008 ford F-250 XLT with a 6.4L and a zf-6
7.3L F-250 is offline
Old 04-06-2008, 02:17 PM   #3 (permalink)
The length of the pipes alone would give you a lot of lag.
Nick
94 F250 IDI T, ZF 5, r/cab, 4x4
04 Dodge CTD, r/cab, 4x4, 48re 4" exh, intake, elbow
94 K2500 6.5, e/cab lb, 4L80e, 3-4" exh, intake.
94 Ram 3500 4x4, r/cab, NV4500 alum fb, work in progress
87 M-B 300D, turbo, custom 3" exh
lots of old diesel iron and gas M-B's
nberchem is offline
Old 04-06-2008, 05:29 PM   #4 (permalink)
88beast's Avatar
would it be better if it was under the cab?
and would auniversal kit work on a diesel? or are they just gas?
I do not have room under hood for the turbo and downpipe btwn firewall and block for stock setup
88beast is offline
Old 04-06-2008, 05:54 PM   #5 (permalink)
I doubt a turbo designed for a gasser would work very well. There are formula's to figure out if a turbo is ideal for a certain engine.
Nick
nberchem is offline
Old 04-06-2008, 09:06 PM   #6 (permalink)
turbos a turbo--but the long pipe length would be a lagging dog----
94_turbo is offline
Old 04-06-2008, 10:26 PM   #7 (permalink)
arthurgoboom's Avatar
The turbocharger needs to be sized correctly to the engine. The basic variables are engine displacement, engine operating RPM, and desired level of boost. The gas engines are mostly around 5.7-6.0 liter, and make peak power around 5000 rpm. These diesels are 6.9 or 7.3 and make most of their power around 2500-3000rpm. The turbo setups for gas engines are going to expect a little more exhaust gas volume because of the higher RPM, meaning if you used one on a diesel you'd probably have a low boost level or maybe even cause a restriction to airflow instead of improving it.
Putting the turbo under the bed would cause a bit more lag, but when steady pulling it shouldn't be a major problem. All you have to do is lean into the throttle 500-1000 feet before you get to the bottom of a hill so you have boost to climb it.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
