Old 11-19-2005, 11:17 AM   #1 (permalink)
Turbo engine
I know this has been up before I just can't remember.
How do you tell if you have turbo motor, (heads are off)
The small valve has a 3/16 looking round divit in the center and the big valves are flat, pistons are flat and have valve depressions down in the top kinda connected together with a small cut out, almost a B shape.
Is this a turbo 93 motor? The valve cover said so?
Tim the toolman Harris
1993 F-350 excab, home made stainless running boards, Z-5 tranny, Tires 235/85/16, 410 rear gear, running gear all new, new injectors on 3-06 code D, reinstalled my ATS TC4305 turbo I rebuilt myself, 3 inch downpipe with 4 inch back and out the side in front of the rear tire, 175,000 miles. Leather seats from a 2002 F 150. http://community.webshots.com/album/548525045nyuVni
Timjoann is offline
Old 11-19-2005, 12:00 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Turbo engine
Check the serial number on the flat portion of the block, left side behind the timing gear cover and ahead of the valley pan. The serial number should start with 7.3TU2 for turbo and 7.3DU2 for IDI.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 11-19-2005, 01:53 PM   #3 (permalink)
Re: Turbo engine
About the only really sure way is to remove a rod and see if it is the large pin type. The block serial number will tell what year and what the rods are but the only sure way is pulling a rod. Any rod, even 6.9 rods fit the 7.3. Pertty much all the idi internal parts cross between the 6.9 and 7.3. Why are the heads off this motor?
icanfixall is offline
Old 11-21-2005, 05:07 AM   #4 (permalink)
Re: Turbo engine
This is my Quote , turbo motor, I pulled out of my truck, it all looked like it was from the factory but, my serial number is a M.
My donor motor runs good but, I was gonna build this motor this winter, number seven piston has .024 wear, got to sleve number 7 and 8 and number 4, the turbo went bad and cooked number seven.
Thanks to you guys i know better these days and what to look for.
Timjoann is offline
Old 11-21-2005, 09:35 AM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Turbo engine
The two rear cylinder holes are bigger 1-6 are 4.1095-4.1115, numbers 7-8 are 4.110-4.1120
The serial number on the block should look like this; # 7.3D U2 U1 073312* with a T after the 7.3T.
