Turbo Impeller - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-24-2009, 12:39 PM Thread Starter
El 'Jefe's Avatar
My Photos: (5)
Send a message via Yahoo to El 'Jefe
Turbo Impeller
How would i go about cleaning oil residue from CDR Valve(now serviced and clean) off of the turbo inlet impeller?
93 7.3L idiTurbo, LWB, 2WD, Crew Cab,ZF5, 4.56RearEnd.
Soon to come:Garrett Dual Ball Bearing T3/60-1with 3" V-band DownPipe Flange on a .63 turbine housing and a 4" compressor inlet,11lbs wastegate, Garrett High Performance Intercooler, 4'' downpipe to a 5'' exhaust all the way back. All on a sesame seed bun.
Don't Worry...I will take Pictures.
El 'Jefe is offline
post #2 of 2 (permalink) Old 08-25-2009, 03:11 AM
My Photos: (13)
You could spray a little carb cleaner on a rag and wipe them down. You dont; want to be spraying anything that would find it's way into the engine.
'92 F-350 Crew Cab dually,7.3 5 spd+ 3 speed Spicer 5831 Brownie, Solid Flywheel w 12 1/4" Kevlar Clutch, ATS turbo, Hypermax Cowl induction, MS Tech Fan Clutch, Custom Aluminum Rodney Red Radiator, 4" Exhaust, Air seat, Western Hauler bed.
RLDSL is offline
