Old 04-25-2005, 01:09 PM   #1 (permalink)
turbo upgrade?
I just bought a 93 7.3 turbo engine to replace my truck's tired 6.9. The new engine has a factory Ford/Garret turbo and stock down pipe. I am looking to do a few upgrades before puting the motor in the truck. Does anyone know if the turbo housing upgrade from ATS is worth the time and cost or is the downpipe the only major upgrade? I already have dual aluminized 4" exhaust on the truck. I'm new to the turbo world so any help or sugestions will be greatly appriciated!
NEW:- 2000 f-350 4x4 dually. Bully Dog exhaust brake. 4" straight pipe with single 5"stack in bed.
CRASHED:-1986 F-350 4x4 dually. Hillsboro flatbed. 3" aluminized exhaust t'd under bed.5" stacks.'94 7.3 turbo diesel with ATS upgrade kit.Kenwood cd player, Autometer; pyro,boost,trany temp,oil pressure, and engine temp. Jasper transmission and transfer case. "B&M suppercooler" Trany cooler. Perma-cool electric fans. Holly "Red" fuel pump. 9' fisher commercial snow plow. Munci live hydo pump; 5 core radiator(can't remember brand) More $$$ then if I'd have bought a new one!!
stevehastings is offline
Old 04-25-2005, 03:58 PM   #2 (permalink)
My Photos: (13)
Re: turbo upgrade?
Everybody who has done the ATS upgrade has been overly happy they have. It is a good deal, bigger DP, bigger exhaust housing, just an improvement all the way around. How many miles and how much did you pay for your set up Sounds like you have a solid combo. Call Ken at dpsperformance.com and ask about the ATS upgrade, I believe he is a dealer and can help you out with the purchase if you want one. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
Old 04-25-2005, 04:55 PM   #3 (permalink)
hesutton's Avatar
My Photos: (30)
Re: turbo upgrade?
I agree with Scotty. I've only heard good things about the ATS upgrade. The stock downpipe is so restrictive, it's almost a joke. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] I'd get the upgrade from the cheapest dealer. Shop around. Here is a LINK to the ATS site. The info in the factory upgrade is at the bottom of the page.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
DYNO YOUR IDI AT THE 2009 RALLY
hesutton is offline
Old 04-25-2005, 10:15 PM   #4 (permalink)
Re: turbo upgrade?
I just bought the motor complete from a salvage yar for $1500.00. It has 98,000 miles on the sped-o. It came with a 30day warrenty so I'm scrambling to get it ready to drop in and fired! My old 6.9 had 246,something before the sped-o quite last winter. [img]/ubbthreads/images/graemlins/mad.gif[/img] For the money I've put into this truck I could have probably bought a new one but oh well. I tried to post a pic of it but must have done something wrong. Thanks for the replies and I'm sure you'll be hearing from me again VERY soon. [img]/ubbthreads/images/graemlins/confused.gif[/img] Steve
Old 04-25-2005, 10:56 PM   #5 (permalink)
Re: turbo upgrade?
A new truck will cost you everytime it breaks down and you need to have it towed to the dealer for computor repairs. The new injectors are about $700.00 each. Ours are about $28.00 each.... Nuff said>>>>>
icanfixall is offline
Old 04-25-2005, 11:32 PM   #6 (permalink)
Re: turbo upgrade?
Got my injectors a couple of weeks ago from a local dealer (but through ebay) for $175 for a complete set of new ones.(Buy 7 get one free? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]) I checked a while back...injectors for the 7.3 powerstroke were in the neighborhood of $300 apiece.
A Cummins ReCon injector for my N14 is only $375 or so. And it will run 600,000 miles. LOL
My pics...
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
Old 04-29-2005, 11:02 AM   #7 (permalink)
Re: turbo upgrade?
Just an update... ATS upgrade kit and new pipes on the way! [img]/ubbthreads/images/graemlins/grin.gif[/img] Still trying to figure out if i want to change all the v-belt pullys from my old 6.9 over to the 7.3 or if i should stay with the serpentene system and try to find a pully for the alternator. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Any sugestions? Steve
Old 04-29-2005, 11:06 AM   #8 (permalink)
Re: turbo upgrade?
What did ya have to give for the ATS upgrade? If you don't mind me asking.
My Truck - 1994 F-350 Crewcab 7.3 Factory Turbo
ATS upgraded Turbo Exhaust Housing, 3" Exhaust Outlet Housing and 3" downpipe, 3.5 the rest of the way back.
DPS Stage 1 Injectors
LGF Propane Injection
Pyro,Boost,water temp,trans temp gauges
K&N Filter
Wife's ride- Red, 2003 Excurision, Eddie Bauer, 6.0l 4x4, 63,000 Miles, Bone Stock
31' Salem LE Travel Trailer
My Pics
bsays is offline
Old 04-29-2005, 11:25 AM   #9 (permalink)
Re: turbo upgrade?
I called two days ago. 500 for the upgrade, 700 with exhaust. Please let us know if it's cheaper anywhere.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 04-29-2005, 12:36 PM   #10 (permalink)
Re: turbo upgrade?
Are you getting the exaust housing for the turbo or just the exaust flange? Somebody had gotten a kit from a place on the internet, i can't remember the name, it was 2 letters, something like J&H Diesel, not sure.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 04-29-2005, 11:43 PM   #11 (permalink)
Re: turbo upgrade?
Still trying to figure out if i want to change all the v-belt pullys from my old 6.9 over to the 7.3 or if i should stay with the serpentene system and try to find a pully for the alternator. Any sugestions? Steve
I'd stay with the serpentine buy a new alt. if all else fails be alot easier and probally better in the long run [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Aric
96 F-350 4x4 regularcab dually 5spd 4.10LS [color:"red"]Home made Bumper[/color]DIY open air intake hypermax dp 4" exhaust DIY exhaust brake [color:"red"]Dump bed[/color]
93 F-250 factory turbo 4x4 extended cab [color:"blue"]MyPics[/color] 4.10 5spd K&N filter ATS outler and down pipe 3in exhaust to twin 5" stacks tweaked wastegate turned up pump LUK clutch boost and pyro and much more to come[color:"blue"]Mickey Thompsons classic II 265 75 16 Courser C/T[/color]
Ford makes it IH shakes it
Don't worry about the mule just load the wagon
93turbo'd_animal is offline
Old 04-30-2005, 11:09 AM   #12 (permalink)
Re: turbo upgrade?
I got mine from ATS for $564.91. I talked to Mike in tech and told him what I wanted. He mixed and matched for me because I needed all the pipes on the motor but didnt need any exhaust pipes. I got the crosover, down pipe,and 1 or 2 more pipes. I also got the larger housing. The Price includes shiping to PA. Steve
Old 04-30-2005, 11:26 AM   #13 (permalink)
Re: turbo upgrade?
J&H Diesel. Paid $545 for whole system, turbo housing, downpipe, exhaust pipes, and muffler. Due to some mixup, they paid my freight. Still sitting in my shed, haven't had time to install.
Ravi is offline
