Old 04-15-2007, 06:59 PM   #1 (permalink)
Turn off with less than 1/4 tank and it won't start back up (Seems like air in fuel?) Wait overnigh
Turn off with less than 1/4 tank and it won't start back up (Seems like air in fuel?) Wait overnight or turn it over for a couple minutes with the starter and it goes (Seems like it's getting gas again).
Any ideas on a fix other than banging on the starter or keeping greater than 1/4th-1/2th tank of gas in it at all times? Any way to prime these things?
Waiting overnight or until the engine is cool also fixes the problem.
1987 e-350 6-9L -- chuggin along at 460k! -- Update: RIP, 467k, overheated.
Replacement: 1990 f250 2wd 7.3 diesel, unknown mileage, $500 at the local auto auction.
johndoe123123 is offline
Old 04-15-2007, 07:16 PM   #2 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
Re: Turn off with less than 1/4 tank and it won't start back up (Seems like air in fuel?) Wait over
My 91 idi cuts out a little before 3/8 of a tank. I would think that your problem is a broken off fuel pickup tube. If it runs and doesnt die when you keep it full, then its definitly the pickup tube. You said if you let it cool, it starts back up. This conflicts with the above idea. Does it just die right out or sputter a little? These fords seem to have problems with the tube breaking off.
Hope this helps,
Anthony
1997 F-350, XLT, dually, crew cab, 7.3 PSD, E4OD auto, B+W turnover goosneck hitch
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
16.66MPG
[IMG src=file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-9.jpg][/IMG]
91diesel is offline
Old 04-15-2007, 07:53 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
As Anthony stated possibly 2 problems the tank pickup and a worn out IP...... Worn out IPs will not start hot, will do great cold. If it was starting then stalling with a hard start then it could be air in the fuel system.
Grab a drink sit down and digest the info on this page........then get back to us with what you think is the problem....
http://www.intellidog.com/dieselmann/idi.htm
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 04-15-2007, 07:54 PM   #4 (permalink)
Re: Turn off with less than 1/4 tank and it won't start back up (Seems like air in fuel?) Wait overnigh
Might help if you run diesel instead.... [img]/ubbthreads/images/graemlins/wink.gif[/img]
Sorry couldn't resist. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
My pics...
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
Old 04-15-2007, 10:19 PM   #5 (permalink)
Thanks guys, I've avoided following the conventional wisdom of air in fuel on this forum because as you said my symptoms are opposite -- OK when cold but bad when HOT. Every other problem here is the opposite [img]/ubbthreads/images/graemlins/frown.gif[/img].
I will read that page and let you know.
Old 04-16-2007, 12:50 AM   #6 (permalink)
My Photos: (10)
another vote for the pickup tube. u used a piece of fuel hose in place with a hose clamp on the top and a bend so it sat in the fuel
kevin
(mine) 94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a used p-stroke exhaust on the end of it 24xxxx miles, amsoil bypass, coolant filter
(dads) 02 350 7.3 powerstroke crew cab 4x4 ESOF
mods: itp in tank/prepump, 4 inch exhaust, ats housing, western diesel gauges, 6.0 transmission cooler, 6.0 Banks "technicooler" intercooler 150 bucks , coolant filter, "OEIS", b&w 5th wheel companion
18xxxx miles
my gallery
WHY THE HELL SHOULD I HAVE TO PUSH 1 FOR ENGLISH?
H O N D A - How Odd No Damn Acceleration
radeon1314 is offline
Old 04-17-2007, 11:17 AM   #7 (permalink)
I had the same problem. Pulled the bed off and found both suction strainer assemblies laying in the bottom of the tank. Used a copper 3/8"od tee on the bottom of a piece of fuel hose with clamps-don't see any need for strainer in the tank because all of the fuel that goes in is filtered and there was absolutely no trash in the bottom after 265,000 miles.
93 F-250 mostly stock 270,000 miles original engine 2nd rebuild on E4OD...92 F-700 Bus/Motor Home 160,000 miles 6.6 Brazilian Ford td engine
wtom24 is offline
