Urgent: lower ball joint won't come off the I-beam side. - Diesel Forum - TheDieselStop.com
Old 11-25-2006, 09:35 PM   #1 (permalink)
Short version:
The lower ball joint won't come off, therefore I can't take the spindle off. I just need to change the upper ball joint, but to do so the spindle has to come off, right? Everything else is ready, but I hammered around the lower ball joint area for about an hour, no luck. What can I do to get the spindle off?
Long story:
The driver side upper ball joint is making some rattling noise, a brief check showed about 1/16 movement, and there are ball joint press on sale for CDN$89 at princessauto, so why not. Got a cheap upper ball joint at NAPA for about $25. I just replaced the upper and lower ball joints on passenger side last year, piece of cake, some hammering, a press borrowed from a friend, a few beers later, all done. So I was plan to do the same thing this time without the beer, but I rememer some post here mentioned you can replace the upper ball joint without remove the spindle. I put the press on the upper ball joint, took a six foot bar, press the h*** out of it, the bottom popped open, but the ball joint stay put. Ooops, looking at the new one, realized I pressed the wrong way, duh, now the upper ball joint is damaged. Proceed to loosen up the lower ball joint in order to remove spindle, but it stuck, I hammered and hammered, it won't even losen a bit. I'm almost out of ideas, except put everything back together, loosen the nut on the lower ball joint a few turns and drive around the block till it come loose. But I'm a bit nervous doing so with a badly damaged upper ball joint. So what should be my next move?
Thanks in advance.
Norm
1990 Ford F-250 Lariat XLT 7.3L diesel NA, two wheel drive, 5 speed manual, 450,000 km. 3.55, 6250 lb...
------ WB:155 TYPE-GVW:X259 BODY:FJM AXLE:39 TAPE:3 SPRING:K F --------
Dual tank, Master/Carter(P74017) electric pumps. OkieGringo idler pulley, K&N air filter, Cat fuel filter, Manual GP switch.
skipper416 is offline   Reply With Quote Quick reply to this message
Old 11-25-2006, 09:41 PM   #2 (permalink)
Re: Urgent: lower ball joint won't come off the I-beam side.
To remove the spindle you need a ball joint fork thing. You need a pretty big one too, rented mine from pep boys, all their ones you could buy weren't big enough.
I had the same exact problem you did. I pretty much beat on that thing all day with anything i could find to no avail, then i went and found that fork and had it off in 5 minutes.... [img]/ubbthreads/images/graemlins/frown.gif[/img]
All you do is hammer the fork inbetween the axel and the spindle around one of the ball joints, and it just pushes it apart and the spindle pops off.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline   Reply With Quote Quick reply to this message
Old 11-25-2006, 09:52 PM   #3 (permalink)
Thanks for the advice, Eric.
Unfortunatly, I'm not aware of any storesd rent specialty tools in the Great White North. Remember in the good old days when I lived in Taxes, I can borrow all the tools I need from AutoZone.
I acturaly have tried to use a pry bar to pry it open with no luck. Is there anyway I can make a simple fork with hard wood or aluminum? Any pictures floating around?
Old 11-25-2006, 11:43 PM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Did you take the large circlip of the bottom ball joint base....
Proud Canadian BOOB man too!!
cdnsarguy is offline   Reply With Quote Quick reply to this message
Old 11-25-2006, 11:48 PM   #5 (permalink)
Yes, sir, the circlip/snapring was off.
Old 11-26-2006, 04:01 AM   #6 (permalink)
My Photos: (16)
you need a ball joint press and lotsa good penatrating oil
'93 F250 SCab XLT, 4X2- 7.3/ZF5/4.10 Banks Wastegated Turbo, Enviro-assult tube
'85 F250 Reg Cab XL, 4X2-6.9/C6/3.54 Racor, Holley Red, Auto Jet 3" out, Air Ride Rear
'93 F150 Reg Cab XLT, 4X4-5.0/AOD/3.55 Pacesetter dual out, Timbren Rear
Some pix/ The fleet
Zrob is offline   Reply With Quote Quick reply to this message
Old 11-26-2006, 06:19 AM   #7 (permalink)
Powerstrokedogg's Avatar
Send a message via ICQ to Powerstrokedogg
you need a bigger hammer [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
and don't be afraid to use it, your not going to hurt anything down there
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
2007 Arctic cat 700 diesel ATV
1975 W900 Kenworth 500 Cummins
1997 Ford school bus 5.9 cummins
Powerstrokedogg is offline   Reply With Quote Quick reply to this message
Old 11-26-2006, 08:42 AM   #8 (permalink)
If you have access to a torch, heat does wonders on things that don't come apart.
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
Greg77 is offline   Reply With Quote Quick reply to this message
Old 11-26-2006, 11:32 AM   #9 (permalink)
zRob, I do have a ball joint press, but I need to take the spindle off first, that's where I got stuck.
PowerStrokeDogg, I'll see if I can find a bigger sledge hammer, I already beat the snot out of it, so I guess some more won't hurt.
Greg77, I'm a little reluctant using heat on suspension parts, so I probably going to use it as last resort.
Thank you guys very much for the advices, I'll give it another try today, it's been snowing outside where I work on my truck, it's going to be a lot of fun.
Old 11-26-2006, 01:29 PM   #10 (permalink)
I wouldn't recommend hammering the metal directly though, that can't be good for anything...
I still vote for the fork, order one on ebay if you have to, it'll get it apart and not damage anything.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
Old 11-26-2006, 08:59 PM   #11 (permalink)
cdnsarguy's Avatar
My Photos: (109)
The shop uses an air hammer less destructive energy.........
Old 12-09-2006, 10:55 PM   #12 (permalink)
Update, I just managed to replace the upper ball joint today, using a big fork I borrowed from a truck maintainance shop next door.
Thank you guys for pointing me to the right direction.
Old 12-10-2006, 08:40 AM   #13 (permalink)
For future information, what you do is loosen the nut till it's at the end of the stud (so the spindle doesn't fall off and get damaged) then you take a large hammer and smack the side of the I beam where the tapered stud goes in. This "shocks" the tapered hole and releases the tapered stud. It usually doesn't take more than a few blows to do the job.
You can do the same thing with tie rod ends.
I learned this some years ago in Auto school, our instructor was an old (probably now dead) Army mechanic who probably did repair work on the Ark.
I never even owned a pickle fork until this year, I had to get one to remove a bad drag link from a steering box and I was afraid to hammer hard and damage the bearings. Pickle forks are "OK" as long as you don't have to re-use the part you are removing.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline   Reply With Quote Quick reply to this message
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
