i seemed to have lost my vaccuum pump bolts when doing some work to my engine. does anyone know what sizes they are or have a pair they wouldn't mind selling?
thanks,
carl
my trucks: 1989 F-250 custom 7.3L idi, regular cab, 5 speed ZF-5 tranny, 4x4, blue w/ blue interior, 229,xxx miles, bronco buckets, 4" custom exhaust, luk smf; http://community.webshots.com/user/tomcatomalley
That's something the ford dealer can tell you from their computer look up, on mine I think they were metric, if you ask them nice they might even fax you the page.
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system. http://community.webshots.com/user/jl_mendoza
This isn't the best advice, but I know that they have a 10mm head on them, and they are less than an inch long. I bet you could go down to the hardware store and buy a small handful of anything close and find what you need. Its a little work, but at least its not every accessory and accessory bracket bolt for a mid 90's Subaru six cylinder. That was NOT fun.
You know, that's one of the whack things I've noticed about this 7.3L in mine...some of the bolts are standard sizes and others are metric. The other day I replaced the Alternator and needed to different wrenches (1 metric, 1 standard). The 2 bolts on the top were metric and the long bolt on the bottom was a standard... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Yeah, I know what you mean. When I ripped the engine out of my old F250 I was pissed about the metric mix. One or the other please.
If you need to put washers on your bolts because they are too long, you have tons of room to do so before they will hit anything.
