Originally Posted by drinkypoo
Classic symptom of air intrusion. Have you done your tank pickups yet?
you ask if i have done my pickups yet. what do you mean?
i found chucks of rubber in my fuel lines and i removed the strainers in both tanks. i had to remove the switch directs the fuel from tanks. so i only have a rubber fuel line from the rear tank to the lift pump. as soon as my friends lift is clear of his camero i will lift it and redo the lines with steel.
it only does it when the tank is at above full.
w85 is thicker than diesel. but not by much. i have wondered if there are still pockets of gas that hits the injector pump and causes this. its is odd but i only worry because i might break the sound barrier and lift off the ground.
Guys i thank you for your help.
jonathan Lunsford (RevJon)
